It is currently Sat Oct 31, 2026 11:34 am
Post Posted: Fri Sep 02, 2011 9:31 am
Hi guys when im driving and i go into neutral my sierra just idles at 1500, everynow and then it raises up to 2000 - 2500 and as of lately had been very high, I just have to let the clutch off without any accelerator and it drives off.
I had a dig around here and tried filling up the radiator with the cap off and warming the engine, but that didnt work.
So then i checked the throttle in my engine bay and it doesnt look right. The spring looks like it has come off and the the throttle is stuck down...
How can I fix it?
is there someone who can fix it for some cash or beer, looks like it would be 5 minute job for someone who knows what theyre doing.
Ive attached photos :P
Uploaded with ImageShack.us
Post Posted: Fri Sep 02, 2011 1:39 pm
where in brissie are u ..
is your zook totally stock..
Vehicle: MY2019 Jimny
Post Posted: Fri Sep 02, 2011 1:41 pm
The munted spring bit is a wax choke.
You can probably disconnect it until you can find a replacement, but it has been a while since I looked into a zook engine bay, so I could be wrong.
Post Posted: Fri Sep 02, 2011 3:48 pm
looks like the cold start choke is stuck on?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Fri Sep 02, 2011 8:49 pm
Its the choke spring. Not having this spring connect will prevent the choke flap closing hence high idle.
Post Posted: Sat Sep 03, 2011 12:13 am
how bad is it to drive on it?
Im in Camp Hill and its completely stock under the engine... anyone know what i can do about this?
Post Posted: Sat Sep 03, 2011 12:38 am
Pull off the carb inlet, and see if there is a butterfly that is moving freely that is connected to the busted spring. If there is, wire it open. That will temporarily get you going a bit better.
Post Posted: Sat Sep 03, 2011 10:54 am
if the water lines to the choke are blocked , wiring open that choke arm will not reduce the high idle.
Users browsing this forum: No registered users and 460 guests
