It is currently Fri Nov 13, 2026 9:27 am
Post new topic Reply to topic  [ 264 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
Post Posted: Thu Jun 23, 2011 9:41 am
I got this w/p pully from santos he said it was of a toyota cant remember what model but it lines up with the std sierra water pump just needed to space it out with small washers as it sits to far back
 Profile YIM
Post Posted: Sat Jun 25, 2011 9:38 am
Okay so I have a g16a block with g13a head
So I have all g13 pulleys and waterpump
My understanding is that I'll have to
Change water pump and pulley back to vitara
Change crank pully to swift mult rib pulley
Run thermo fan
Can some one clarify this please
Post Posted: Sat Jun 25, 2011 9:34 pm
Yep all sounds good. But a g16a waterpump pully bolt config is the same as sierra so you could use sierra fan and not have the thermo.
I just fitted the 8 valve g16a vitara water pump pully to my g13a pump and it fits. Used sierra fan on the front of it.
Post Posted: Sat Jun 25, 2011 9:45 pm
Ill run a vitara clutch fan instead I think
So Is the vitara crank pulley a 5 bolt pattern and water pump pulley 4 bolt pattern
My timing cog is g13a 4 bolt so I'll have to get a swift pulley
And you say use a vit w/p pulley on the Sierra w/p wich should be the same bolt pattern as my g13 water pump
Post Posted: Sat Jun 25, 2011 9:55 pm
So Is the vitara crank pulley a 5 bolt pattern and water pump pulley 4 bolt pattern 8 valve g16a yes
And you say use a vit w/p pulley on the Sierra w/p wich should be the same bolt pattern as my g13 water pump as long as your g13 w/p has the 50odd mm front wheel then yes. swift has 70odd mm front wheel on w/p
Post Posted: Sat Jun 25, 2011 10:11 pm
Post Posted: Wed Jun 29, 2011 7:10 am
any one have issues with the alt rubbing on the rag joint?
Post Posted: Wed Jun 29, 2011 7:17 am
No, it could if I had it all the way out on the adjuster. Run a smaller belt? Or else I saw Damo flipped the uni, not for that but good idea if its an issue.
Damo wrote:
and put the uni joint near the steering box.
Post Posted: Sun Jul 24, 2011 2:56 am
Hi,
I'm looking at doing this upgrade over the next few weeks and wanted to confirm the parts I require as well as how to wire it up.
I've got the g16a with 8 valve motor, so I'm guessing that I'll require an alternator bracket from a g13 to make it fit.
Does any one have a wiring diagram, instructions or photos that would help me wire it up?
Any assistance is much appreciated.
Cheers,
Mic
Post Posted: Wed Aug 17, 2011 11:15 am
Quick question, does any one see a problem running a 100amp cable from alt to battery.
Also what size fuse to run with this cable.
Only reason I used 100amp cable and not 70amp is because I had shit loads of dual battery cable laying around
Post Posted: Sat Sep 03, 2011 9:45 am
will be fine as long as you use the right size fusible link in it
 Profile YIM
Post Posted: Sat Sep 03, 2011 9:49 am
Already did it :helloo:
Post Posted: Mon Sep 19, 2011 4:03 am
Would an AU/BA 110amp fit on a G16B? If so, any recommendation for bracket to use?
The Zooks of Hazzard
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Wed Oct 05, 2011 8:17 am
I've tracked a EL Alt one down but noticed that these ones have 5 ribs/groves... can this help in the aligning of the Alternator Belt or does the belt need to be against the edge of the pulley?
I assume $75 is a reasonable price for one ???
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Vehicle: '94 suzuki maruti
Post Posted: Wed Oct 05, 2011 9:34 am
8O local wrecker here has them for $40... but that one looks pretty clean
Post Posted: Tue Oct 18, 2011 4:40 am
What size fusable link did you use? I can see everyones meant to use 70amp wire, but no ones answered your question about the fusable link size.
Post Posted: Tue Oct 18, 2011 4:49 am
Also I no longer require this plus on my stock sierra loom due to g16b. Can I use this as the alternator plug? It fits perfectly and is two pin. This is for a 110 amp alternator. Will there be any problems involved?
Post Posted: Tue Oct 18, 2011 4:50 am
Pics help Image
It was the a vacuum solenoid thing on the old carbie motor.
Post Posted: Sun Nov 06, 2011 6:38 pm
If ppl have a g13b gti motor this conversion is much easy. Cuz u don't need to change pulleys I think
Post Posted: Sun Nov 13, 2011 3:10 am
Does any one know what you have to do to fit a falcon alt to a m13a Jimny.
I've got a brand new 110amp alt sitting around doing nothing.
Vehicle: Clown Car..
Post Posted: Sun Nov 13, 2011 3:17 am
Is the difference between the Bosch and Mitsu. alternators listed!? glanced thru the thread, but buggered if I can find out other one is 108 the other is 110amp..
Post Posted: Sun Nov 13, 2011 3:40 am
EF/EL V8 = Bosch
EF/EL 6 cyl = Mitsubishi
Post Posted: Sun Nov 13, 2011 3:43 am
otherwise they are the same!? mounting wise, output etc. I already run a 110. inquiring for another member... twill be going onto a 1.6 inj.
Post Posted: Sun Nov 13, 2011 4:05 am
Ill buy it off ya.
Post Posted: Sun Nov 13, 2011 4:08 am
Ill buy it off ya.
$1million thanks :lol:
Foolspeed the bosch has different mounting to the mitsubishi alt
Only the Mitsubishi one bolts on I think I read
Post Posted: Sun Nov 13, 2011 4:19 am
cheers zooky08 :) will pass the info along to the required source :)
Post Posted: Sun Nov 13, 2011 5:14 am
you can use a daihatsu charade water pump pully on the std sierra water pump to run the mulit rid belt but you will have to space the pully out with a thin washer on each fan bolt on the back of the pully then you will just need to change the crank pully to multi rib as well
 Profile YIM
Post Posted: Sun Nov 13, 2011 10:58 am
what year?? this is awesome news, i need to do this now im running a thermo fan...
Vehicle: Suzuki Sierra
Post Posted: Sun Nov 13, 2011 9:55 pm
Bosch is also listed as being for a 6cyl so Burson tell me.
The Bosch plug sticks out the side more than the Mitsu one.
Post Posted: Sun Nov 13, 2011 11:43 pm
Just confirmed with Santos that you can use a vitara pulley with the sierra water pump and fan.
You won't need to use any washers or spacers...it will just bolt on and you can run the ribbed belt like on the GTi (make sure you get the pulley from a vitara with an engine fan as later models may be electric)
Users browsing this forum: No registered users and 69 guests
