It is currently Fri Jul 31, 2026 7:16 pm
Post Posted: Sun Sep 04, 2011 6:44 am
Can someone please explaine why people invert there shocks. What are the benefits/negatives
Post Posted: Sun Sep 04, 2011 6:47 am
SierraDan wrote:
Inverted means upside down.
Inboarded means you bring the top shock mound inward(closer together)
http://www.auszookers.com/index.php?nam ... ic&t=21485
BUT, inboarding the shocks allows room to fit a longer shock for better travel if the springs allow it.
Post Posted: Sun Sep 04, 2011 6:58 am
Hey sierraDan, I know what it means/ how it's done. I want to know why
What does it acheive? What are the negatives and positives of this set up
Post Posted: Sun Sep 04, 2011 7:29 am
My build shows how I did it. I have a lux commo shock combo and the lean softens them up. Plus I get extra flex.
Post Posted: Sun Sep 04, 2011 7:40 am
Positives: See above.
Negatives: You have to move the top mounts. And they soften them up slightly (Good or bad depending on how the shock rides already.)
Post Posted: Sun Sep 04, 2011 7:41 am
cool, does inverting serve a purpose
Post Posted: Sun Sep 04, 2011 7:43 am
Chris88 wrote:
cool, does inverting serve a perpose
Inverting, not really other than a possible clearance issue it may solve. But with my rancho's (twin tube shock) inverted, the shocks don't work at all.
Inboarding:
Post Posted: Sun Sep 04, 2011 8:00 am
actually it changes the damping ratio by lots :wink:
I'm now running shocks with about twice the damping to match the front.
but yes it allows a lot longer shock to be installed
thanks
Post Posted: Sun Sep 04, 2011 9:48 am
Inboarding the shocks effectively increases the amount of axle travel/for a given amount shock travel. Think trigonometry.
Due to the change in axle travel/shock travel the dampening rate of the shock is also effectively decreased.
Lil Foot!
Vehicle: Ducati Monster
Post Posted: Sun Sep 04, 2011 10:05 am
so what is the advantage of inverting them rather than inboarding them or do you do the both together?
Post Posted: Sun Sep 04, 2011 10:06 am
from what i can work out inverting them gets the body of the shock away from the axle tube.
Vehicle: 2018 DMAX
Post Posted: Sun Sep 04, 2011 10:36 am
And if you really need to do this, it would make sense to run them the correct way with new mounts.. Not all shocks are designed to work upside down..
I run mine inboard, helps clear everything better.
Post Posted: Sun Sep 04, 2011 11:01 am
My rancho's cease to do anything while upside down.
Post Posted: Sun Sep 04, 2011 11:15 am
I thought rancho's cease to do anything period :P
Lil Foot!
Post Posted: Sun Sep 04, 2011 11:17 am
Well they absorb shock. But they're shit. Only reason i still have the rear ones is because i dont wanna buy new shocks now, when ill need longer ones in a few months.
Post Posted: Mon Sep 05, 2011 1:11 am
how much work is required to inboard them??
Every problem can be solved with a Ratchet.
Vehicle: 2018 DMAX
Post Posted: Mon Sep 05, 2011 1:13 am
You can buy bolt in kits from lowrange for cheap.. Or make something to bolt up for even cheaper. Or just weld a new cross member in..
Post Posted: Mon Sep 05, 2011 3:48 am
X2 a lot of shocks do't work at all upside down, or the valving gets VERY VERY soft.
The adjustable ranchos I have here are pretty good for what I do. I would prefer a gas charged shock, but find one that is adjustable is really hard to do.
I carry enough weight to drop the rear end to the bumpstops sometimes, and then sometimes I am empty. I also drive everywhere I wheel and then drive home, so a different valving for road than highway is nice to have.
I have the knob shocks though, not the new 9-way air operated.
Post Posted: Tue Sep 06, 2011 7:28 am
This whole "inverting" thing brings the lolz.
The term was somehow dreamed up by retarded hilux owners who thought that rotating their shocks from running fore-aft to across the car was (a)cool and (b) "inverting" them.
WTF.
The rear shocks on a SWB Sierra are already freakin' "inverted" based on what the hilux mouth breathers reckon.
If inverted actually means what it's supposed to mean, i.e "turning the shocks upside down" then only mono tube gas and remote reservoir shocks work upside down.
If inverted means "leaning the tops in" then yes it can work, assuming you are prepared for the loss of damping rate. A shock at 45 degrees will be 40% softer than the same shock vertical.
I know this stuff was mentioned across a couple of posts here but it can't hurt to reiterate it.
Steve
Post Posted: Tue Sep 06, 2011 8:11 am
You got a smile out of me Steve, thanks for clarifying it and getting it all in one post.
One thing I would like to mention is that leaning the shocks in will also cause a bit of body roll.
Think about the shocks at the end of the axles, and the end of the body. Now when you hit a bump going around a corner, all that weight from the momentum falls on the very outside of the axles, and the weight it is bearing is from the body at the outside.
Now imagine top of the shocks are in the center of the body. Go around that same corner and hit that same bump. Now the body will pivot over that spot on the body the shocks are mounted to.
Once you get enough force to start the body leaning, tuck one side down, and have the inside of the body come up, the weight pivots on the shock mounts, and transfers over to that outside and there is nothing on the outside of the body to dampen it. Kind of like a teeter totter on the play ground if you know what I mean.
Code:
Like this
_________
Versus
_________
If the body can move around/tilt those uprights, it is obvious which one will be more stable on angles and around corners. If you consider the loss in effective dampening that Steve pointed out, that makes it even worse.
Post Posted: Tue Sep 06, 2011 8:13 am
LOTS more body roll! roundabouts became hard to drive because i was near in the passenger seat haha.
Vehicle: 2018 DMAX
Post Posted: Tue Sep 06, 2011 8:20 am
And to stop that loss of dampening you run a heavier shock, I use patrol rears and there quite a comfy ride...
Post Posted: Tue Sep 06, 2011 10:32 am
mouth breathers
I lol'd
Post Posted: Tue Sep 06, 2011 11:39 am
I'm running patrol shocks 10degrees in/10degrees forward and it's stiff :twisted:
Post Posted: Tue Sep 06, 2011 1:29 pm
The Lowrange kit only fits SWBs. The LWB (either Sierra or Maruti) have slightly different spacing and the Lowrange kit will need to be modified.
Users browsing this forum: No registered users and 452 guests
