It is currently Sat Oct 03, 2026 11:36 pm
Vehicle: yellow 83 sierra
Post Posted: Tue Sep 06, 2011 6:59 am
hi i have a G16B block out of a 1991 LWB vitara that im wanting to get rid of. i dorve the car home to use it only for parts but i dont need the block and the engine didnt blow an ounce but i wouldnt trust it i would rebuild it just incase. i would only be looking at selling it for about $200ono
i do have other vitara engine parts
power steering pump works great didnt make a sound
A/C pump
exhaust from cat back no manifold
automatic transmission worked great (without transfer case)
PM me if your interested in any of the parts that i got for sale
Last edited by orangeshannon on Wed Sep 14, 2011 11:22 pm, edited 4 times in total.
Post Posted: Tue Sep 06, 2011 7:06 am
is it the g16b that matches up with the head off a g13b?
Post Posted: Tue Sep 06, 2011 7:09 am
yeh from what i have heard that the G series engines pretty much match up with any of them best to have a llok on the forum if they do im pretty sure they do but dont take my work for it
Vehicle: Daisy
Post Posted: Tue Sep 06, 2011 7:33 am
Do you happen to have the steering box? and is it the one that fits into a SWB sierra with benT's kit?
Post Posted: Tue Sep 06, 2011 7:38 am
pics
Vehicle: Suzuki Grand Vitara XL7 2004
Post Posted: Tue Sep 06, 2011 9:20 am
Alternator?
price?
and Dang you live in Burwood, if only i was still in Cheltenham >.>
still interetsed though!!!
Post Posted: Wed Sep 07, 2011 1:59 am
for sale
Block G16B with 16 valve pistons and water pump
Autotrans without transfer case
Exhaust from the cat back
A/C pump
Power steering p[ump
Post Posted: Sun Sep 11, 2011 6:37 am
front brake rotors and calipers both sold
Post Posted: Sun Sep 11, 2011 6:39 am
engine (block only)
gearbox (auto without transfer case)
standard exhaust
A/C pump
power steering pump
all still for sale
Last edited by orangeshannon on Sun Sep 11, 2011 10:17 am, edited 1 time in total.
Vehicle: 02 jimny
Post Posted: Sun Sep 11, 2011 9:03 am
Interested in the ps pump. What other ps parts you got wanting to put in a sierra
LIVING LIFE ON THE EDGE, TILL YA ROLL
Post Posted: Mon Sep 12, 2011 11:23 pm
also have a complete rear diff including drums
all the front diff parts avaliable not including rotors or calipers and cvs need work
Vehicle: vitara
Post Posted: Tue Sep 13, 2011 7:40 am
hi bloke , what you asking for the auto?
Post Posted: Tue Sep 13, 2011 8:12 am
pm sent
Post Posted: Tue Sep 13, 2011 11:27 pm
i might add that the car has never been off road used only around the city so theres nothing wrong with the transfer case works perfectly he guy i bourght it off said that i had never been taken out or rear wheel drive but low high and four low work fine no noise smooth gear change
Post Posted: Tue Sep 13, 2011 11:30 pm
G16 B engine block including flywheel and standrad tourqe converter
$200
Automatic gearbox worked no noise or problems selected every gear no drama
$200
transfer case never been taken out of rear wheel drive but four hi and low work a treat
$100
front diff
$100
rear diff including brakes
$100
front and rear springs
$50
Post Posted: Thu Sep 15, 2011 9:24 am
all parts listed avaliable
will start taking these parts off the car this weekend so pick up anytime will be avaliable. also im will to deliver within 50km for cost of fuel
Post Posted: Thu Sep 15, 2011 9:25 am
how much for gearbox plus ecu and loom?
Post Posted: Thu Sep 15, 2011 9:32 am
also i have a G16B head (inparts suit reco) $100-
and i have a efi manifold with all injectors just been removed from the car when it was running $80
1992 G16B vitara efi ecu $100
i am also removing the efi wiring loom cut down to the electronics just for efi $50
1992 EFI air flow sensor exellent working condition $160
EFI exhaust manifold with OXY sensor $30
the pipe for air intake that goes across the rocker cover and all piping for air intake $50
air box including pipe inlet to air box $50
1992 G16B 16 valve rocker cover painted red with runs or i can sand blust it back to bare alloy $30
Post Posted: Thu Sep 15, 2011 9:33 am
pm me with an offer if you think its abit much and i'll consider it
Post Posted: Thu Sep 15, 2011 9:38 am
the prices are very flexiable make me an offer.
these parts really need to go now i have no use for them anymore
Post Posted: Thu Sep 15, 2011 9:39 am
do you still have the loom for the auto?
Post Posted: Thu Sep 15, 2011 9:41 am
which part of it do you need the bit from the fire wall to the box? or from the fire wall to where ever it goes? i have a almost complete loom its just the efi is getting cut out of it so someone is able to do a G16B efi sierra conversion.
Post Posted: Thu Sep 15, 2011 9:44 am
dunno. i have a manual 16v vitara motor that i want to stick a auto on so i can slap it in my sierra.
Post Posted: Thu Sep 15, 2011 10:05 am
:helloo:
Armsup
Cheers for that mate!!!
Dave
Post Posted: Thu Sep 15, 2011 10:06 am
im glad to help out anytime
Post Posted: Thu Sep 15, 2011 10:10 am
You'll need the flex plate, converter and auto box. Also the TCM and wiring loom, and ECU.
Also get the auto lines ( hard lines ) with the banjo bolts. And the shifter and cables.
Post Posted: Fri Sep 16, 2011 6:16 am
also i have a radiator for it looks to be in good nik the car never heated up past 1/4 mark may only need to be flushed out.
i will start posting up lots of pics this weekend of all the parts im selling
Post Posted: Fri Sep 16, 2011 6:20 am
this is the rocker cover as you can see is has a bit of run on it i can eaither sand it back and respray in the metalic red colour or i could sandblast it back to bare metal for you for no extra cost
Post Posted: Sat Sep 17, 2011 4:04 am
some pics and more to come
Post Posted: Sat Sep 17, 2011 4:05 am
EXHAUST MANIFOLD HAS BEEN CRACKED AND REWELDED BEFOR I BOURGHT THE CAR SO IM GIVING IT AWAY FOR FREE USE AS A SPARE
Users browsing this forum: No registered users and 27 guests
