It is currently Thu Jul 30, 2026 10:14 am
Post Posted: Wed Sep 07, 2011 4:45 am
Hey all,
I've being doing a little thinking about the whole RUF idea for my zook. Can anyone fill be in on what might be the issues with making a no weld RUF solution. My very very very basic thoughts are well... a picture tells a thousand words....
 Profile WWW ICQ YIM
Post Posted: Wed Sep 07, 2011 4:46 am
After all that effort why wouldn't ya give it a bit of hot metal to hold it together?
Post Posted: Wed Sep 07, 2011 4:48 am
I was thinking about an easily reversible option
 Profile WWW ICQ YIM
Post Posted: Wed Sep 07, 2011 4:51 am
even having crush tube in there i reckon it would still wont be strong enough, dont forget about all the weight in the front
Post Posted: Wed Sep 07, 2011 4:58 am
Grind the welds out?
Post Posted: Wed Sep 07, 2011 5:04 am
With a chassis extension for RUF the bump stop mounts need to be moved forward aswell... something to think about...
Post Posted: Wed Sep 07, 2011 5:07 am
Cheers for the reminder! Luckily that's not such a hard issue to tackle.
 Profile WWW ICQ YIM
Post Posted: Wed Sep 07, 2011 5:11 am
You'll need a front driveshaft spacer as well...
all that leverage on 4 pissy bolts... 8O
Post Posted: Wed Sep 07, 2011 5:13 am
It's been a long time since I was sat down in Mr O'Neill's physics class but I figured that the load would be on the inner sleeve and not the bolts....
.....I would bet money that I'm wrong though.... :)
 Profile WWW ICQ YIM
Post Posted: Wed Sep 07, 2011 5:20 am
I think you should draw the shackle hanger aswell. You may find that they need to occupy the same space. :?
Post Posted: Wed Sep 07, 2011 5:27 am
All 'that' weight hey?? Seriously how much weight do you reckon is in the front end?
Lil Foot!
Post Posted: Wed Sep 07, 2011 5:35 am
i reckon that a pothole at 100kph would be a reasonable shock load.
Post Posted: Wed Sep 07, 2011 5:41 am
less then 150kg mabby. im not sure really but still alot of weight on 4 bolts
Post Posted: Wed Sep 07, 2011 5:45 am
Well really its the front half of the car.... :? There is alot of force on that shackle hanger. Without getting into vectors and transfering forces, lets just say that continued loading of the above design MAY fail. It probably wouldn't happen for a while, but its probably not a bad arrangement. If the 'socket' extended into the rails a little further, and was 5mm wall thickness, it may do quite well. The further in it went, the less 'work' the bolts would have to do.
Post Posted: Wed Sep 07, 2011 5:54 am
This and maybe vertical crush tubes and bolts.
Lil Foot!
Post Posted: Wed Sep 07, 2011 6:03 am
These are just some models I drew up at work, I'll check it out properly when I get home but I am hopeful that it won't be an issue as I aim to have the shackle no more than vertical at full droop and the spring should in retard theory not foul on the original hanger while compressed.... but like I said, I'd bet I'm wrong :)
I was trying to avoid any sort of drilling, welding, grinding etc. Basically the goal is that you would only require a socket set.
 Profile WWW ICQ YIM
Post Posted: Wed Sep 07, 2011 6:24 am
I would reckon that where the bolts pass through the chassis rail would over time flog out from the repeated back and forward levering placed on them, not to mention the sideways movement when turning, maybe adding something that also attaches to teh stock shackle hanger would help, AKA Calmini shackle reversal
I dont think you could produce something that is a snug enough fit to get around that given the chassis are rarely square
Post Posted: Wed Sep 07, 2011 6:25 am
Oh and fix whatever is allowing a spammer to log into your email or delete me from your address book :wink:
Post Posted: Wed Sep 07, 2011 9:51 pm
Bloody Yahoo was compromised....
...on the plus side, now you know where to buy cheap Viagra in Canada!
 Profile WWW ICQ YIM
Users browsing this forum: No registered users and 55 guests
