It is currently Wed Oct 28, 2026 3:02 pm
Vehicle: Ducati Monster
Post Posted: Fri Sep 09, 2011 2:19 am
chaps i am painting my block after having it cold tanked and decked so it clean, etc. but needs a final go over before painting.
what my question is do i need a special primer due to it being ally or is the normal primer for the enamel the go?(VHT high temp engine enamel from autopro)
Also do I need to do any other special prep before i hit it with the primer again because its ally?
cheers
http://i774.photobucket.com/albums/yy22 ... decked.jpg
Post Posted: Fri Sep 09, 2011 2:45 am
ricer
:thefinger:
Post Posted: Fri Sep 09, 2011 2:48 am
fuck you pal
Post Posted: Fri Sep 09, 2011 2:53 am
personally after having a paited block i'd leave it bare alloy it's much easier to locate a leak if you ever get one, nothing trying to find the source of an oil leak on a black block.
+ the extra weight of the paint & primer will effect your ET times down the quarter mile.
Post Posted: Fri Sep 09, 2011 2:55 am
:lol:
you will need a high temp etch prime. dunno if such a thing exists, i certainly never came across one when i was playing with paint.
Post Posted: Fri Sep 09, 2011 2:58 am
yeah my zook is gonna be fully sick down the quarter, can anyone help me install my transbrake????
Post Posted: Fri Sep 09, 2011 3:06 am
so are you cracking a jonno or do ya want the correct answer?
Post Posted: Fri Sep 09, 2011 3:08 am
nah mate im not cracking a jonno, i am just taking the piss out of myself cause it did sound like a ricer question, I would like to know if i need to do anything special though
Post Posted: Fri Sep 09, 2011 3:09 am
as shep said, i don't think you can get Hi-Temp primer, i'd just hit it with prep-sol/wax n grease remover & hit it with a few light coats.
if you can get some sort of heat into it before, during & after painting it will have a better chance of sticking. if you can make up a small 3 sided spray booth out of carboard & get a blow heater in there to generate some heat.
be warned blow heaters & paint vapours aren't that good for your health + the blow heater will never be the same after.
what colour are you looking at painting it?
with my years of experience as a keyboard warrior/ricer I found go fast red is good for 1/2 a second down the quarter, yellow will bring you max revs up 1500rpm, blue will add torque to the range of 15-20Nm, magenta will attract members of the opposite sex & black will bring the gay.
** graffiti artists spray can trick in cold weather is to heat the cans either with hot water or gently with the heat gun.
Post Posted: Fri Sep 09, 2011 3:10 am
the answer is in my second post
:lol: cracking a jonno, you're so mean shep.
Post Posted: Fri Sep 09, 2011 3:12 am
hahaha.
etch prime is what ya need.
Post Posted: Fri Sep 09, 2011 3:13 am
Gus cheers mate, I have a heat gun lined up to get some heat in it and i wasn't decided about the colour but since yellow will give me an extra 1500rpm i better go for that, definitely dont want any gays so will avoid the black
Post Posted: Fri Sep 09, 2011 3:15 am
thanks shep. i finally saw the tiny writing after you pointed it out
you big butch bitch :lol:
Post Posted: Fri Sep 09, 2011 3:28 am
paint it in clear coat, it will make us both happy... you get your painted block, i get the raw alloy look. 8)
Post Posted: Fri Sep 09, 2011 3:31 am
actually have thought about that hey, but not much point really maybe this wasnt such a smoking hot idea after all
Post Posted: Fri Sep 09, 2011 3:41 am
the only reason i mentioned the clear coat is a mate does some seriously cool wrought iron work & gets all his finished artsy-fartsy type work powder coated in clear & it looks so nice with the depth of the clear on top of the raw metal.
i keep having to tell myself, it's a workhorse not a show car... :wink:
Post Posted: Fri Sep 09, 2011 3:44 am
I spent a bit of time with alloy cleaner trying to get the shite shit off my block. In the end I just hit it with a silver coloured heat paint. No flaking etc after a couple of years now.
Maybe glow paint? :lol:
Vehicle: 92 Suzuki Sierra
Post Posted: Fri Sep 09, 2011 3:51 am
You know white would be cool, real easy to spot leaks, or yellow.
Still just keep bare... its not going to rust after all. (but maybe you have some ideas for you rockin'new valve cover!)
-Santos
Post Posted: Fri Sep 09, 2011 4:07 am
have tossed around the white/yellow idea, maybe with black sump, rocker cover, extractors & intake manifold bit its starting to sound like one of those ideas that seems like a top one when you think it up but in practice actually sux balls
Post Posted: Fri Sep 09, 2011 4:18 am
The VHT range of engine hi temp paints do come out very well provided you prepare the surface. I used VHT satin and gloss black on this one:
Lil Foot!
Post Posted: Fri Sep 09, 2011 7:54 am
with high temp paint applications , less is more.
and yes etch primer, one lite coat
Users browsing this forum: No registered users and 309 guests
