It is currently Tue Oct 27, 2026 5:03 pm
Post Posted: Sat Sep 10, 2011 3:06 am
just put the 4age in my car wired everything up and no spark computer has power injectors work starter works but the coil has no power
ive been told it could be the ignighter
anyone around brisbane northside that could lend a hand that knows what they are doing
cheers nathan
Post Posted: Sat Sep 10, 2011 3:10 am
Give it ing + from some other place & see if it go's.....
Who reduced the harness???
Post Posted: Sat Sep 10, 2011 3:11 am
tried that still nothing
and what do you mean about the harness
rust is lighter then carbon fiber
Post Posted: Sat Sep 10, 2011 3:12 am
Do you have battery volt's at the ignighter plug???
Post Posted: Sat Sep 10, 2011 3:19 am
yes there is 12 volts at the igniter plug on one wire im just thinking it could be a timing issue with the dizzy i just put constant 12 volts and negative on the coil pack and still no spark
Post Posted: Sat Sep 10, 2011 4:18 am
It wont, the ecu & dizzy give it it's neg pulse, the body of the coil does need an earth ( that go's for coil pack's to) but the neg of a coil is the trigger.
put a test light from + to - on the coil & crank, if it flash's, look at timing...
If you get to stuck I may be able to come up monday arvo...
Post Posted: Sat Sep 10, 2011 4:42 am
i just conected one more wire to the computer and it just fired about 3 times and nothing but i think its flooded and the batterys flat i have something to work with now ill let you know how it goes thanks
Post Posted: Sat Sep 10, 2011 5:36 am
here you go streaky it sparks sometimes but not all the time and even when it fires the light i put on the coil pack doesnt light up im starting to think its not getting enough power to it
Post Posted: Sat Sep 10, 2011 5:50 am
Bugger! ssounds like a pain tin the arse mate! :( , hope you get it sorted soon! :)
Post Posted: Sat Sep 10, 2011 6:04 am
yea i kno its almost time to burn it and start over
Vehicle: Daisy
Post Posted: Sat Sep 10, 2011 7:04 am
But surely it would be easier to fix as is than it is to fly shep to Brisbane?
Post Posted: Sat Sep 10, 2011 7:24 am
all the welding is done unfortunetly
and brisbane turbo and tuning recon its a wiring issue but they wont say where and i think they know exactly what it is they want me to get it towed to them and they'll get it going but thats going to cost a mint when all i was going to do is to get them to tune it when its running
Post Posted: Sat Sep 10, 2011 7:53 am
When you say it sometimes has spark and sometimes it doesn't. Is there a pattern? I.e when its cold it has spark but when its warmer it doesn't?? (Does it lose spark after a couple cranks)
Post Posted: Sat Sep 10, 2011 8:11 am
no completly ramdom and it hasnt run yet only just put it in and had a few fires and this is the first time the motor has run in 8-10 years but i just rebuilt it
Post Posted: Sat Sep 10, 2011 8:37 am
Time for you to give up :cry:
....and sell it to me :lol:
Post Posted: Sat Sep 10, 2011 8:40 am
i wish 2stroker would get back to me and say he got that special 4age to sierra instuction manual he was talking about it would really help :roll:
Post Posted: Sat Sep 10, 2011 9:11 am
location??
Post Posted: Sat Sep 10, 2011 9:19 am
albany creek
Post Posted: Sat Sep 10, 2011 10:09 am
ive just tested all the imputs and outputs on the ecu and i have 12 volts going in and only 1.3 volts coming out and there should be 12 by the book so im starting to think the ecu is ratshit but i need to try to get another standard ecu just to see if im right :?
all the power going into it is right but whats coming out isnt the fuel drum sitting next to the car and the lighter is lookiing better and better :x
Post Posted: Sat Sep 10, 2011 10:36 am
Just for shit's & tickle's. earth the body of the ecu...
Post Posted: Sat Sep 10, 2011 10:46 am
ok ill give that a try
a new ecu is $1400 8O i can buy 2 suzukis for that
Post Posted: Sat Sep 10, 2011 10:54 am
nope didnt work any more ideas ???
Post Posted: Sat Sep 10, 2011 10:26 pm
It's a shame about the distance, otherwise I'd be around with an occiloscope.
So you've got fuel, that pretty much rules out the crank angle sensing (whatever it is on that engine.)
If not overly familiar with the 4AGE setup, and aparently it changed a couple of times over the years. But if you've got a ignitor, have you been able to try another one? Typically, the ECU wont fail, because that's not under any electrical stress, the ignitor on the other hand are the stressed components in the ignition system. That's why they made them easy to replace.
I'm guessing it's a version with coil packs? That pretty much rules out the coils being bad, because typically they fail on an individual cylinder rather than all together.
Really you want an occiliscope to probe around and find out what's happening. Without one it's just a bunch of guessing...
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Sat Sep 10, 2011 10:37 pm
Rent a car with the same engine in it and borrow the ECU.
I've had ECUs repaired before, might be a good option.
Carb-N-Ject in Underwood test and repair them in Brizzy.
Post Posted: Sat Sep 10, 2011 11:48 pm
double check your ecu earth's, I think there is 3 that are meant to go to the intake manifold, they HAVE to be there & with good connection....
Post Posted: Sun Sep 11, 2011 2:10 am
Mate I can't get that diagram he is away, why do t you borrow an igniter and ecu from max, he is just around the corner
Post Posted: Sun Sep 11, 2011 4:38 am
thanks everyone i found out what was wrong apparently these older computers if they loose power for a long time they loose all ther memory and dont know whether they are a 4age or a suzuki 1.3 8O and i dont have a toyota computer to upload the memory
but they guy also said they are self tought and if i keep persisting it will find out what it is
so i left it on charge overnight and came back and kept trying and it eventually got better and better and now its working fine you hit the key and it goes
im just glad nothing was wrong and its all sorted thanks everyone
:roll: and it goes real hard :twisted:
Vehicle: Daisy
Post Posted: Sun Sep 11, 2011 7:14 am
Nice work!
Post Posted: Sun Sep 11, 2011 8:26 am
wow thats good to know
 Profile YIM
Post Posted: Sun Sep 11, 2011 8:36 pm
Yes, very usefull information.
Users browsing this forum: Google [Bot] and 242 guests
