It is currently Mon Jun 22, 2026 11:59 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2
Post Posted: Sun Sep 11, 2011 4:56 am
also do u have an exaust leak? if mine is leaking and i give it a hard time it will blow flames... not like that but yeah...
let us know how to make it do it tho!!!
Post Posted: Sun Sep 11, 2011 5:06 am
Get a 20v
Sik as drover, 32" mongrels, 4age 20v, 2" sus, 2"
Post Posted: Sun Sep 11, 2011 5:14 am
i just got my 4age going and it shoots blue flames out and im running 98 octane and the exhaust smells real sweet it must be a 4ag thing
rust is lighter then carbon fiber
Post Posted: Sun Sep 11, 2011 6:27 am
Definitely a 4age thing, they do smell good :lol:
Post Posted: Sun Sep 11, 2011 7:03 am
I dont get any sound so I cant tell if its doing it at idle or revving it what but,
an exhaust leak, retarded timing, rich mixture or a combination of all of them will give you flames on overrun
The big part is the retarded timing, its heaps easier to make it happen if you still have a good flame in teh cylinder when the exhaust valve opens
Post Posted: Sun Sep 11, 2011 10:54 pm
As for flame in the cylinder when the exhaust valve open this pretty much says it all, this was my first test run on the engine without exhaust, I'd imagine more than enough flame to ignite the excess fuel
I just need to find the source of the excess juice
Injectors are fine I'll be swapping the ecu this arvo I have a hunch that will be causing the injectors to pump a dick load more than normal
http://m.youtube.com/#/watch?v=UL12UwwYOmA
Post Posted: Sun Sep 11, 2011 11:08 pm
You gots the mad throttle response.
Post Posted: Sun Sep 11, 2011 11:13 pm
With quad throttle bodies there is deffinately no lag in response
Post Posted: Mon Sep 12, 2011 6:01 am
in my old soarer i had a 3 inch exhaust no cat the gearbox in them is designed to misfire the first change then go into gear so it doesnt hammer the box supposed to be a luxury thing smoother shifts or sumthing it retards the engine timing before changing it used to shoot flames without the cat on gear change then i put a good shift kit in the box after that no flames just wheelspin on changes.
Vehicle: LPG 1.6 Sierra
Post Posted: Mon Sep 12, 2011 7:37 am
Why it's Grease Lightning :lol:
Oh man, what i'd give for a bit on flame on demand 8) Take that tailgaters!!!
Vehicle: 1995 SWB Sierra TinTop
Post Posted: Mon Sep 12, 2011 10:31 am
youve cut your valve seats out running it without extractors...
95 Sierra SJ70 TinTop
Post Posted: Mon Sep 12, 2011 10:34 am
Lil Foot!
Post Posted: Mon Sep 12, 2011 10:46 am
JrZook wrote:
X2 what the??
Post Posted: Mon Sep 12, 2011 10:54 am
x3? :blink:
Post Posted: Mon Sep 12, 2011 11:00 am
It's always a concern when you've got a bad exhaust manifold gasket leak, that running it like that for long time will end up stuffing a valve. Problem is oxygen gets in the leak between pulses and oxidizes the red hot exhaust valves. I assume this is what you're talking about.
Having said that, I'd find it highly unlikely that could happen in this instance because it takes quite a while to happen, and the engine needs to have running hard (e.g. highway speeds) to get the valves up to a very high temp where the oxidization can occour.
Post Posted: Mon Sep 12, 2011 9:20 pm
No mre bbq"s
Ahhhhhhhhhhh CRAP, Kermy is boring again
Changed the ecu with my spare and he no longer farts fire
So let's start the bidding at $1000 for my plug n play FIRE FARTING, FLAME THROWING, BUMPER BURNING, OVER FUELING ECU!!!!!!!!
Do I hear a $1000 lol :wink:
Users browsing this forum: Google Adsense [Bot] and 46 guests
