It is currently Fri Oct 30, 2026 3:58 am
Post Posted: Sat Sep 10, 2011 2:36 pm
hey people, i need some help withing something simple.....
just installed some driving lights and when i switch them on they have a faint glow????? i thought i have wired it up all right but i guess not. any one know what it might be???
Post Posted: Sat Sep 10, 2011 2:42 pm
where did you get your power feed from?
do each light have a separate earth wire & power wire or are they earthed through the mounting bolt & only have a power wire?
Post Posted: Sat Sep 10, 2011 2:45 pm
it was a pre fabed loom, and it am just testing it straight from the battery. i must admit i have never had much luck with lights.....
Post Posted: Sat Sep 10, 2011 2:51 pm
it has two wires comming from the relay, one goes to the battery and the other is earthed out.
have a look through this thread for a guide to wiring it all up, the suzuki's are negatively switched which means most prefabbed looms will need tweaking.
http://www.auszookers.com/index.php?nam ... spotlights
maybe there is an AZ'er near you that could give you a hand?
to get them to work well, they need a good clean earth as well as a decent power feed.
Vehicle: LJ20 LJ50
Post Posted: Sat Sep 10, 2011 3:02 pm
Whos loom is it???
Did you follow instrucions???
Camels have nice toes
Post Posted: Sat Sep 10, 2011 3:04 pm
followed the instructions to the T. it was a present although so i am not really sure. XS or something like that
Vehicle: LJ20 LJ50
Post Posted: Sat Sep 10, 2011 3:06 pm
Should have gotten one of royces looms. He will reply in the morning so best wait for his advice. He is the sierra electrical master
Post Posted: Sat Sep 10, 2011 3:15 pm
ok, thanks mate :) i must be a zook thing cos i have never had trouble with other 4bys just my sierra but i cant remember how i did it and i dont have it here to look at :(
Post Posted: Sat Sep 10, 2011 3:17 pm
that link in my first post will walk you thru on what to hook up where, the neg switching on the zooks is what throws most people out.
Post Posted: Sat Sep 10, 2011 5:52 pm
yeh i think it might be the fact that there is only one wire from the spotlights to the relay, not two as royces diogram suggests. and that is the only thing i can see different. i did not think it would make that much difference, i unpluged one of the lights and the other went heaps brighter...............XD
Post Posted: Sat Sep 10, 2011 8:46 pm
sounds like you arent getting enough power somewhere, check your connection to the battery is nice and solid
Vehicle: '94 suzuki maruti
Post Posted: Sat Sep 10, 2011 9:17 pm
sounds like theyre hooked up in series rather than parallel...
Post Posted: Sat Sep 10, 2011 10:34 pm
X2
Post Posted: Sun Sep 11, 2011 12:55 am
nah wouldn't one be bright and one be dull for that?
and when he unplugs one the would break the circuit for series.
you have a bad connection some where.
unless the lights are just plain rubbish?
Post Posted: Sun Sep 11, 2011 3:13 am
Either parallel or in series, both lights will illuminate the same, not one brighter than the other, so, both bright or both dull.
Post Posted: Sun Sep 11, 2011 8:16 am
x2, assuming no issues with spotlights themselves.
good article to have a read of is http://www.auszookers.com/index.php?nam ... sc&start=0
has a lot of info on headlight upgrade, but on the diagrams you can see the wiring for the spotties, may be of some help...
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Sep 11, 2011 8:34 am
You mentioned that they were 'XS or something" Are they the Auto XS lights from Aldi. (Yellow and balck box). I purchased a set of these when they were on special last week and then promptly took them back for a refund. I tested them and found they were not very bright (in fact my 34 year old Cibie Oscars were 10 times better). They do have both an earth and a power lead directly to each light but one of the connectors fell apart when I was testing them and also I suspected a dodgy relay. If they are the Aldi ones you might want to check that all the connectors are actually making a good contact and also try another relay. Royce's wiring loom might be the way to go if you are not experienced.
Post Posted: Sun Sep 11, 2011 10:26 am
yeh those are the ones.
i attached the light straight to the battery and the brightness blew me away. i think its all to do with the supplied loom as the wires are all thin shit. will rip it all out and use some good wire and see how i go. i do like the idea of royces loom but i am a little short of cash. will get one later :D
Post Posted: Sun Sep 11, 2011 12:29 pm
I disagree...
yeah mate just rewire them =]
Post Posted: Sun Sep 11, 2011 1:51 pm
i have given up for the night as now one of my headkights dont work and its not the globe cos i tested it in the other side :(
Post Posted: Sun Sep 11, 2011 1:58 pm
Check the fuses :wink:
Post Posted: Sun Sep 11, 2011 2:07 pm
i thought that if it was a fuse they would both be out, ok will go out and av a look :)
Post Posted: Sun Sep 11, 2011 2:18 pm
Halle-FUCKING-lujah Its all good!!!! bright as. thank you all for your help :)
I think i will still upgrade to royces lume later on but this will do for now XD
Post Posted: Sun Sep 11, 2011 2:20 pm
Pretty sure the run a left and right headlight fuse.
Post Posted: Sun Sep 11, 2011 4:25 pm
just follow the guid provided in the link above.
the trick is to use fat ass wire!!!!
if u have a pre fabed loom that is not a brighteyes then do not follow the instructions.
and you will prob have to upgrade the wires that carry the load (battery to relay and then to lights)
Earth it out well!!!
and you are done :)
Post Posted: Sun Sep 11, 2011 8:38 pm
spotties i bought were the same, wire looked like it was 10amp crap... i tossed it and went overkill with 50A wire. :wink:
Users browsing this forum: Google [Bot] and 474 guests
