It is currently Tue Oct 13, 2026 1:36 am
Post Posted: Fri Nov 28, 2008 2:11 am
i want to do a dual batteries set up in my zook, has any one done it, if have can you tell me how hard and how much
thanks
Post Posted: Fri Nov 28, 2008 2:16 am
I did it, $300 for battery, $100 for stuff to make a box for it, $100 for controller, few hundred for cables :)
the batteries are dearer now though :wink:
its one of them piece of string things, what do you want it to do will dictate what you need and what it costs, step 1 is to figure what you want to run and how lond and how much space you wish to give to it
Post Posted: Fri Nov 28, 2008 2:37 am
i want to run a fridge and lights
wish i had another zuk
Post Posted: Fri Nov 28, 2008 2:43 am
what brand and size fridge?
Post Posted: Fri Nov 28, 2008 2:45 am
engel or waeco 18L to 60L
Post Posted: Fri Nov 28, 2008 2:49 am
make sure you go with an engel... might cost a little extra but they are way more efficent but y not upgrade the alternator to a falcon one and put an ultima battery which has deep cycle and normal in one. It will probably cost the same as a dual battery set up but you have a better battery and something to charge it
how long do you want to run it without starting the car, how long will you run the engine once you do and what temperatures will the fridge be in?
same for the lights
Post Posted: Fri Nov 28, 2008 2:56 am
same for the lights
i want it so i can leave the car not run for a nite and start it in the morning for about 10 minutes or so and the fridge will be ruinning at around 1'c
i got 4 spot lights on the roof 2on the bullbar for now and i want to but some under the zook for nite off roading
Post Posted: Fri Nov 28, 2008 3:11 am
ok the lights dont need a dual battery while the engine is running, just a big alternator, assuming you have 100w bulbs your sticking 60 amps jsut into lights on high beam
the fridge over night will be lucky to use 15 ah/hrs so a 40ah/hr battery would be fine, if you think you are going to charge the battery back up in 10 mins running your kidding yourself, you need near on 2 hours driving PER DAY for every 24hours of fridge use, this is more cause deep cycle batteries need a lot more charge time as they wont take a lot of current when charging
if you want to run the fridge longer (say 24hr period) with minimum charge time consider a 60ah/hr AGM battery
Users browsing this forum: No registered users and 258 guests
