It is currently Thu Jul 30, 2026 1:02 pm
Vehicle: Vitara 1995
Post Posted: Sun Sep 11, 2011 11:17 am
In my last parts order for an engine build a non genuine part was chosen.
Sadly I must say....as the part is somewhat different.
What should I do, return it, or is this the replacement part for a possibly discontinued part?
Please comment if you have recent knowledge.
Post Posted: Sun Sep 11, 2011 11:25 am
this is where it goes for anyone curious right above the oil filter
Post Posted: Sun Sep 11, 2011 11:26 am
That's a pressure sender , just change the connector on the wire, no problem...
Post Posted: Sun Sep 11, 2011 11:34 am
where do I get a connector like that?
Post Posted: Sun Sep 11, 2011 8:42 pm
it uses the same connector, flat spade female slips over it :wink:
Post Posted: Tue Sep 13, 2011 11:25 am
been to Dick Smith, no connectors like this. Would Jaycar have it or am I looking in the wrong places?
Post Posted: Tue Sep 13, 2011 11:33 am
use the same connector as the old switch http://www.google.com.au/imgres?q=femal ... 2CQ&zoom=1 it slides over the round end
Post Posted: Tue Sep 13, 2011 11:56 am
http://www.google.com.au/imgres?q=femal ... OCg&zoom=1
Vehicle: SJ80, SE416
Post Posted: Tue Sep 13, 2011 10:41 pm
Is there any benefit to be gained from replacing an oil pressure sender?
I doubt the OE sender would ever fail in maybe 1,000,000km
Post Posted: Tue Sep 13, 2011 10:51 pm
Ill assume thats not a pic of your engine cause the head is olf and the oil filter looks to cost about 50c
but yeah this type of terminal jsut pushes onto it Image
Reubs, oil pressure switches fail quite a bit, either switching too low or high or not at all
Post Posted: Wed Sep 14, 2011 1:12 am
Okay - thanks for that insight - just never personally seen one fail.
Post Posted: Sun Sep 25, 2011 1:12 am
aha, thanks! Now I get how they connect.
The engine on that picture was my engine, but that was the 1st or 2nd block. I am up to the 4th block now, but it should look the same. The oil filter on there was one that got delivered to me before the rebuild process began.
Users browsing this forum: sideways and 258 guests
