It is currently Wed Jul 29, 2026 11:58 pm
Post Posted: Thu Sep 15, 2011 1:57 am
So I think my winters mud plugging efforts are starting to show up... I've got a seeping/leaking/dripping front crankshaft seal in my Vitara.
Does anyone know how hard a job is it to replace? I've never really had to put a spanner on the motor since I got it. It looks like there is a heap of crap that needs to come off to get to it or am I better off just farming it out to my Suzuki guy?
Post Posted: Thu Sep 15, 2011 2:02 am
Farm it out. 8O
Block is upside down.
Post Posted: Thu Sep 15, 2011 2:04 am
Pic of motor front on.
Post Posted: Thu Sep 15, 2011 2:06 am
So it looks like you have to pull all the ancillary belts off, the rocker cover, the pullys and idlers, the crank case, the timing chain and guide ( maybe) then the seal cover and maybe the tooth drive gear on the crank aswell.
Post Posted: Thu Sep 15, 2011 2:14 am
fark 8O
Post Posted: Thu Sep 15, 2011 2:21 am
looking at the FSM, it looks like it's just the timing chain cover crankshaft seal... might as well do the timing chain while its apart.
Post Posted: Thu Sep 15, 2011 3:28 am
WTF? does the seal not jsut push into teh housing behind the bottom pulley?
Post Posted: Thu Sep 15, 2011 3:38 am
you're correct royce, bloody ripper!
looking at the FSM again, it does just push into the timing chain cover from the outside. (behind the pulley)
Post Posted: Thu Sep 15, 2011 7:38 am
Armsup
The timing cover's do leak to, not a common problem tho.
Post Posted: Thu Sep 15, 2011 8:01 am
i gave it a good clean up & it is coming from the behind the bottom pulley & it's getting spread by the engine fan all over the place once it reaches the edge of the block & sump... it's been seeping for a while but my skid plates stop the drops falling straight on the driveway for all to see. :crazy:
Post Posted: Thu Sep 15, 2011 8:21 am
Pop the seal out, replace with a genuine one... :helloo:
Post Posted: Thu Sep 15, 2011 8:27 am
atari i've done this on my GV....took about 3 hours and that included removing the radiator. No special tools or anything
My Grand Vitara
Post Posted: Thu Sep 15, 2011 8:32 am
sweet 8)
Post Posted: Thu Sep 15, 2011 8:39 am
When you get the seal out, inspect the machined surface on the crank for any damage all the way around. Sometimes some shit gets stuck in the seal and chews the crank out over time. Not very nice...
If it is munted, you may chose to do nothing about it and just chuck another seal in. But at least you'll know it's not likely to last long...
Post Posted: Thu Sep 15, 2011 8:46 am
I've been thinking that it might not be that flash in there after the winter it's had it might need a speedy sleeving or something, I think I'm just going to drop if off to Mr Suzuki & him to fix it while I thrash one of their loan cars to death.
Post Posted: Thu Sep 15, 2011 8:51 am
Yeah it's up to you, they do get old and rooted without stuffing the crank. In which case you'd save yourself a small fortune by doing it yourself.
Personally I'd give it a crack. If the crank sealing surface is rooted, just whack a new seal in for now then when it flogs out give it to suzi then.
Post Posted: Thu Sep 15, 2011 8:53 am
Gus you wouldn't by chance have a skidpan day coming up... say a day like this might tie in perfectly with the Silver Princess being in the shop and you being in a loan vehicle???
Stocker
Post Posted: Thu Sep 15, 2011 9:07 am
no, but if it's front wheel drive i will be going past macca's & grabbing a couple of trays.
Post Posted: Thu Sep 15, 2011 9:10 am
make sure you stick some P Plates on... otherwise the authorities might get wise...
Stocker
Post Posted: Fri Sep 16, 2011 1:40 am
booked it in for monday morning... CBF'd dealing with it if it does need a speedy sleeve so close to our trip away. going to get him to stick on a new serpentine belt while he's got it as the one that's on there is cracked like a mofo.
Post Posted: Fri Sep 16, 2011 5:34 am
I've always left rad in, but I'm awesome.... :helloo: :blink: :roll:
Post Posted: Fri Sep 16, 2011 5:39 am
thanks for offering, jump on a plane & i'll pick you up when you get here. :D
Post Posted: Fri Sep 16, 2011 6:49 am
:P I want coke & hooker's!!!!! :P
Post Posted: Fri Sep 16, 2011 6:58 am
Armsup sounds fair to me.... what flight are you catching?
Post Posted: Fri Sep 16, 2011 7:01 am
:? you have to book it.. :?
& I want more coke if I have to touch your ball's... :roll:
Post Posted: Fri Sep 16, 2011 7:03 am
there is not enough coke in the world to compensate for that 8O
Post Posted: Fri Sep 16, 2011 7:50 am
:roll: Prude!!!!! :roll:
Post Posted: Fri Sep 16, 2011 9:37 am
:lol: :lol:
My Grand Vitara
Post Posted: Tue Sep 20, 2011 11:37 am
3hrs labour + parts & it's all good, there was a fair bit of grit in there from this winters swimming lesson.
probably could have done it at home but had a serious case of the CBF's
Users browsing this forum: Google [Bot] and 529 guests
