It is currently Tue Nov 03, 2026 4:53 am
Post new topic Reply to topic  [ 118 posts ]  Go to page Previous  1, 2, 3, 4  Next
Post Posted: Tue Nov 18, 2008 11:10 pm
i'll see how much it costs and i'll go from there.
Post Posted: Wed Nov 19, 2008 7:13 pm
VP/VR commo heater hose cut down
AE80/82 corolla and 1.6 Laser radiator hoses. The hose i'm holding is cut so its a 90deg bend
Brass bush i knocked up to connect the 2 radiator hoses
Post Posted: Wed Nov 19, 2008 7:28 pm
Nice work Chinny! Did you make a note of the part numbers of your hoses? Will be handy down the track when you need to replace them :wink:
Post Posted: Thu Nov 20, 2008 11:54 am
Yes i did :)
Post Posted: Fri Nov 28, 2008 7:57 pm
Off to exhaust shop today. Then to Auto leccy's for wiring next week. Need hose for air box to throttle body and custom accelerator cable and it should done :D:D
Post Posted: Fri Nov 28, 2008 8:34 pm
When r we going wheelin Chinny? :lol:
Post Posted: Fri Nov 28, 2008 8:45 pm
This has got to be the world's fastest Zook build 8O
Post Posted: Sat Nov 29, 2008 5:36 am
When its driving :D
I want it done for my straddy trip in 5 weeks :)
Post Posted: Sun Nov 30, 2008 3:06 pm
few more pics
Post Posted: Sun Nov 30, 2008 3:08 pm
the top radiator hose is only temporarily fixed that way. I'm making a bracket that will hold it away from the manifold.
Post Posted: Mon Dec 01, 2008 2:44 am
All lookin real good Chinny.
Is that clear hose you have on the inlet side of your high pressure fuel pump rated for use with fuel?
Post Posted: Mon Dec 01, 2008 6:37 am
nice build up mate. been keenly watching it. will be fun up at strad
where bouts did you get the fuel pump mounting bracket? that looks like it would cut down a lot of noise from it.
keep up the good work!
Post Posted: Mon Dec 01, 2008 12:48 pm
its petrol resistant, we use it for air line at work
Post Posted: Mon Dec 01, 2008 12:50 pm
Thanks mate. Got fuel pump bracket from tweakit performance in nsw
Post Posted: Mon Dec 01, 2008 6:38 pm
OK cool. I was curious because I have some of that stuff at home i'm using for airlines too.
Post Posted: Sun Dec 14, 2008 1:43 am
hey mate bought a gti to do the conversion but liked it so much that ill keep it, now ive bought another gti engine today. and have the massive task of installing it.
are there any tricky bits that you didnt mention?
Lj81.
Ke20.
Baleno.
Post Posted: Sun Dec 14, 2008 5:27 pm
Yeah there's quite a bit i haven't mentioned. A bit of custom fabrication. Its not rocket science but. If you have any questions i'll help you out best i can.
Post Posted: Mon Dec 15, 2008 5:24 pm
thanks mate. its a month away from starting yet though. my friend is putting a turbo on his getting it all done professionally. and after he's done it all ill just do the same. yeh it'll be turbo'd with 31's @_@
approx 130 kw
Lj81.
Ke20.
Baleno.
Post Posted: Wed Dec 17, 2008 3:35 am
that'll be alright. I've the SR20 TB and its going on soon as i get the car back. i'll see how it goes when its all tuned and cleaned up. Thought about putting a 1.6 block on the GTi head?
Post Posted: Thu Dec 18, 2008 1:14 am
na i didnt think of that i probs wont bother. second thoughts i might not turbo alot of stuffing around sr20 tb. and extractors should be plenty my sierra only weighs under 900 kg. ute @_@ with 100kw pretty impressive
Lj81.
Ke20.
Baleno.
Post Posted: Thu Dec 18, 2008 10:14 pm
I'll tell you how it goes when its all running 8)
Post Posted: Sat Dec 20, 2008 11:54 pm
I reckon not too long after you get it running, we'll see a thread in this section about Chinny making a turbo manifold :wink:
Post Posted: Sun Dec 21, 2008 2:33 pm
ho ho ho damo, stop tempting me!!
Post Posted: Mon Jan 05, 2009 8:18 pm
lookin good man. im just been doing my gti motor conversion the last week. pretty much done the same as you except i modded my gti dizzy to work with the angle drive kit.
just wondering where you got the extractors and how much they charged you if you dont mind me askin.
Post Posted: Tue Jan 06, 2009 12:27 am
not a bad setup i done mine a while ago with a t25 and have had no dramas so far they have alot more top end i reckon
Post Posted: Tue Jan 06, 2009 2:15 am
Bought em off a guy on ebay that makes them $240. maximum pipes or something in NSW. I wasn't too happy with the result, mainly because i had to file out some of the holes and cut some off the flange just to get it to fit. and the dump pipe interfered with the engine mount bracket. Learn from my mistake. Get them made from a local place.
Post Posted: Tue Jan 06, 2009 1:11 pm
Should have just made your own turbo manifold :mrgreen:
Post Posted: Wed Jan 07, 2009 1:05 am
by the way try and get some of these i think there valiant v8
http://www.roadlessgear.com/page/RGL/PROD/E/RG241
Post Posted: Thu Jan 08, 2009 10:56 pm
yeah they're off an american dodge pickup or something
ordered
Post Posted: Sun Jan 25, 2009 4:35 pm
So what's going on Chinny? Got it back from the auto leccy yet?
