It is currently Sun Aug 02, 2026 6:07 pm
Post Posted: Sat Sep 17, 2011 11:19 am
Ok I have a question about the throttle response on my LJ50.
When I release the throttle, i.e lift foot from the accelerator pedal, it takes several seconds for the revs to drop right down.
A cursory check of the linkages and cable seems to be ok. It drives quite well otherwise but revs drops slow enough that when shifting up the car lurches a little.
Is something wrong here?
Post Posted: Sat Sep 17, 2011 11:27 am
What kind of carby does it run? Sounds like something sticking inside
Post Posted: Sat Sep 17, 2011 11:29 am
Stock setup entirely except for the fuel pump.
Post Posted: Sat Sep 17, 2011 11:30 am
But are they side or down draught?
Post Posted: Sat Sep 17, 2011 11:32 am
Ah yes, the 50 has a downdraft solex.
Post Posted: Sat Sep 17, 2011 11:35 am
it's the flywheel spinning down. when you are revving the engine the flywheel gets a heap of momentum, when you back off, the compression of the engine isn't enough to bring it back to idle straight away.
how many seconds is several seconds?
If you don't get stuck you aint tryin' hard enough
Post Posted: Sat Sep 17, 2011 11:49 am
I would say about 7 - 10 seconds. However it can take quite a while for it to get right back to idle. Most of the revs are washed of in say the first 5 seconds then slowly back to idle.
Post Posted: Sat Sep 17, 2011 11:52 am
Sticky butterfly in the carby?
Post Posted: Sat Sep 17, 2011 12:30 pm
Does it still do it with the choke on a bit?
Post Posted: Sat Sep 17, 2011 12:54 pm
Carb throttle return spring? They can sometimes stretch and fail to snap the throttle plate shut quickly, and after 30-odd years, can become fatigued.
I had a spring fail completely on me once, engine still merrily revved with foot completely off the acc pedal. Only way to stop was turn off ignition key.
Post Posted: Sat Sep 17, 2011 1:17 pm
side draft su type carbs rev high ,
the only thing stopping it is the throttle cable.
I agree new spring.
(ex moke owner, they used su's)
Post Posted: Sat Sep 17, 2011 8:16 pm
As said, they're a downdraught solex type carb. They have a tendancy to rev on a little, mine does, as Littlejeep described. A airleak will contribute to the run on, check the throttle shaft bushes and butterfly also the distributor advance weights, particularly if you are already running too much advance.
Post Posted: Sat Sep 17, 2011 11:42 pm
Thanks guys. That gives me a few things for me to inspect. To answer Sideways, it still seems to do it with the choke on a bit, but obviously not as much since the revs are higher anyway with the choke on.
Users browsing this forum: No registered users and 290 guests
