check out these guys. just need to confirm if there broken or not. as you can see the rubber bits are seperated from the other bits. one is just seperated from the metal. and one is seperated on the rubber bit
It's a sketchy picture mate but yeah it looks busted. From memory it should look like a block of rubber with a bolt out either end. The metal surrounds should stop horizontal rotation but if the rubber itself is separated then they're shot but they're cheep ($30 ea when I did mine)
Users browsing this forum: Google [Bot] and 265 guests
