It is currently Sat Aug 01, 2026 11:07 am
Post Posted: Sat Sep 17, 2011 11:48 pm
Have search to many threads to read so ill just ask.
I have a 97 vitara with a 16b and need a new clutch im building for Tuff Truck the car will run standard engine with extractors standard gear box but with a divorced sierra case with 6.4s diffs will be after market 60 series running 5.29s with e lockers front and rear tyres are 40 inch sticky treps on beadlocked rims oh yeh it will be 4 wheel steer.
So do I just go with the standard clutch or a heavey duty one have read that the heavey duty are good but can cause clutch cables to break if so how often .The fly wheel will be machined and a new sigot bearing used
Any help would be great with part numbers and prices.
Thanks
Duncan
Team Evolution
Post Posted: Sun Sep 18, 2011 1:40 am
hey Duncan,
sounds like a beast we need pics please. i think the std clutch is generally better and yeah the HD clutches have issue with the cable snapping. i cant give you a life expectancy as i dont run a hd clutch.
you running this and ur red sierra?
Post Posted: Sun Sep 18, 2011 1:57 am
sean at suzistore said the only reason people snap clutch cables on the HD clutches is cos they set the pedal wrong (something along those lines).
running the g16b and in a competition scenario with large tyres i reckon you're best to go with a HD clutch.
Post Posted: Sun Sep 18, 2011 2:07 am
i tried a RPM hd clutch on a 8vg16 and went through 3 cables in a weekend. everything was set up
according to the FSM including cable and pedal freeplay.
Post Posted: Sun Sep 18, 2011 2:09 am
fair enough... i'm on my 3rd HD clutch and still on the factory cable.. my first was an exedy and the 2nd two are jimny clutches.
Vehicle: Yamaha scooter, 50cc
Post Posted: Sun Sep 18, 2011 4:05 am
If your building it for tuff truck type comps, why not go with an auto?
Post Posted: Sun Sep 18, 2011 4:46 am
why not convert to hydraulic
growing old is nature, growing up is choice.
Post Posted: Sun Sep 18, 2011 9:42 am
You have t/case gears so there is no need for a HD clutch.
Post Posted: Sun Sep 18, 2011 9:50 am
i have never had issues with a stock clutch.
stock clutch will work fine, youll never be slipping it if you have enough gears
Post Posted: Sun Sep 18, 2011 11:13 pm
Thanks guys ok how do you convert to hydraulic that would be great has anyone done it if so part numbers and pics would be great i would do it in a flash
Users browsing this forum: No registered users and 219 guests
