It is currently Sat Sep 26, 2026 1:06 am
Post Posted: Thu Sep 22, 2011 9:40 am
Hey, so when I turn tightish corners my car jerks around kinda sounds similar to a bugged cv, but defiantly coming from
The rear, also some times after Turning it makes a large bang noise.
Any ideas?
Post Posted: Thu Sep 22, 2011 9:51 am
What kind of car?
Post Posted: Thu Sep 22, 2011 9:53 am
auto locker?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Thu Sep 22, 2011 10:03 am
Sorry 84 zook swb hi top
And its no "auto locker" something is wrong
Vehicle: 2018 DMAX
Post Posted: Thu Sep 22, 2011 10:12 am
May have lost a tooth or two from a sun gear or something... Try drain your oil and see if you can find anything in it..
Post Posted: Thu Sep 22, 2011 10:13 am
Does it make any noises? It might be spider gears in the diff jamming on the tight turns from worn washers/shims, bad/worn teeth.
Post Posted: Thu Sep 22, 2011 10:25 am
Yeh sounds exactly the same as a bugged cv like clicking
Post Posted: Thu Sep 22, 2011 11:05 am
If it's when in 4wd and on road it's more than likely transfer wind up
Post Posted: Thu Sep 22, 2011 11:57 am
Nah not in 4b and no hubs locked
Post Posted: Thu Sep 22, 2011 3:52 pm
defiantly sounds like worn or broken teeth. like it was said before try draining the diff oil and check for metal shaving. Also feel the oil between ur fingers to see if its gritty
Vitara JX 1.6, straight through 2 1/4" exhaust, 2.
Users browsing this forum: Google [Bot] and 87 guests
