It is currently Thu Nov 05, 2026 8:00 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page 1, 2, 3  Next
Vehicle: Zookless
Post Posted: Sun Sep 25, 2011 11:27 am
I thought I'd finally get around to bolting this in...
Vitara power steering pump and box will be used with a BenT adaptor kit.
I started with the pump.
Here's the mount adaptor that comes in BenT's kit. It's bolted to a G16B.
And here's the pump bolted to the adaptor:
All good, but doesn't leave room for my A/C compressor :(
Then I thought, I've got a Vitara (Baleno) engine, so this Vitara pump should bolt straight on :P
And it does! I will have to modify the passenger side radiator mount to clear the pulley. I'll do that when I have the radiator out next weekend.
Here's the pump mounted low on the block. I've removed the pulley for the time being, but it lines up perfectly. Notice I've flipped the adaptor plate. That will be used to mount the A/C bracket.
A/C bracket bolted to adaptor plate:
Reckon I've got enough compressors? :lol:
Post Posted: Mon Sep 26, 2011 6:40 am
With the pump down low (in the org pos) when the eng move's, the pull WILL hit the rad bracket & shed your belt.....
Post Posted: Mon Sep 26, 2011 7:45 am
jeez, i thought my engine bay was full of stuff. Does the p/steer and aircon run of 1 shared belt on the baleno/vitara? Ive found that with my baleno motor i mounted the pump on the adaptor bracket, it just lightly touches the overflow bottle at the full stretch of the engine mounts but nothing major
Vehicle: Zookless
Post Posted: Mon Sep 26, 2011 7:57 am
Don't worry Stekky, I'll cut enough out so it doesn't hit :wink:
Yes Birko, that's exactly what I'm going to do. I think the overflow bottle is clear, if not, it's easy to move anyway.
Looks like I've found a ribbed pulley too :D
Can anyone tell me how to get the old one off the compressor? I've undone the bolt on the front, but it won't budge...
Post Posted: Mon Sep 26, 2011 8:00 am
:helloo: I thought the same...........then on the first hill.... :roll:
spent the rest of the day strong arming the thing through G/H
Post Posted: Mon Sep 26, 2011 8:18 am
Maybe try 3 arm bearing puller? I use this for these kinda jobs
Vehicle: Zookless
Post Posted: Mon Sep 26, 2011 8:42 am
I have. All it did was bend the v-pulley :?
Post Posted: Mon Sep 26, 2011 10:50 am
Well I think the only solution then is to remove all AC bits, pack em in a box and send them to me Armsup
Lil Foot!
Post Posted: Mon Sep 26, 2011 11:05 am
Hey dave, I think the pump I have is Jimny as I think my brother sold the sierra one with his car when Gricey bought it. may still work?
Vehicle: Zookless
Post Posted: Mon Sep 26, 2011 1:04 pm
Does it look like mine Brenno? I seem to remember yours being a little smaller maybe?
Even so, it should still work, it's not as if we need ice cold A/C in Tassie anyway :lol:
Dan, you only just missed out. Would have been free for you too :| :arrow: :finger:
Vehicle: Zookless
Post Posted: Wed Oct 05, 2011 12:51 pm
So, a week later, and it's all done, well pretty much...
Ben-T adaptor plate on:
And if anyone is wondering, the gold square metal section that comes with the kit is a spacer for the radiator bracket. (Not installed yet in pic)
The Vit steering box is a little longer than the Sierra one. I had to shorten the steering shaft, which was easy enough.
I also had to remove my bulbar and grind out a section. Not really a worry, but just a pain in the arse as it doesn't come off easy!
Vit steering box installed:
I've used the stock Vit hydraulic lines for now. I'll get some flexible custom lines made up as these hang down below the splash guard.
Not 5 minutes after finishing the install, I got a call from some mates who were bogged out at Hollybank. The test-run was pretty good :D
The steering is (obviously) lighter than before, but also feels quite different. Slower, to a point, then it feels quicker??
Maybe the fact that I have now removed the sway bar and steering dampener has something to do with that :lol:
Vehicle: Zookless
Post Posted: Tue Oct 11, 2011 9:51 am
Here's the new lines made up.
I took the originals to Enzed and told them the length I required.
The tape is about 1m long.
The high pressure line retains the original fit fittings, just attached to a flexible hose.
Low pressure lines are 1200mm and 450mm. Lengths will depend on where you fit your fluid reservoir.
Post Posted: Tue Oct 11, 2011 9:53 am
Lil Foot!
Vehicle: Zookless
Post Posted: Tue Oct 11, 2011 9:57 am
About $150 :?
But that included the awesome hose-clamps too (pity I broke one when I tightened it too much).
It might be cheaper to go to an actual power steering place...
Post Posted: Tue Oct 11, 2011 7:37 pm
CairnsZook wrote:
About $150 :?
Yeah rookie mistake - I go to onsite hydraulics down here in Hobart. $70 for a full new line, Enzed were going to charge $90 to do a 10cm section on rubber line, or $150 for a complete new one. The Onsite item was rubber hose so it was easy to route.
Post Posted: Sat Dec 03, 2011 11:46 pm
So the kit is a direct bolt on no major modifications required?
Post Posted: Sun Dec 04, 2011 2:11 am
CairnsZook wrote:
About $150 :?
thats cheap! i paid $290 if that makes you feel any better....
Vehicle: Zookless
Post Posted: Sun Dec 04, 2011 2:30 am
Yep, unless you have A/C, then you might have to move some stuff around.
Post Posted: Tue Sep 04, 2012 6:56 am
Is the Sierra pitman used on the vitara steering box?
Post Posted: Tue Sep 04, 2012 7:52 am
Nope, vitara arm
Vehicle: Coily.
Post Posted: Tue Sep 04, 2012 9:03 am
..you couldn't post the actual length of the hose on the high pressure fittings by any chance,having trouble lining it up on the tape.TIA.
Post Posted: Tue Sep 04, 2012 1:12 pm
Does anyone make a drop pitman for a vitara steering box? Or will my Sierra pitman fit the vitara box?
Post Posted: Tue Sep 04, 2012 2:13 pm
Sierra pitman wont fit. I have one off a Tarago on my Vit box. Have a look on the shitbox you've been thrashing around, the pitman on that will probably fit Armsup
Post Posted: Tue Sep 04, 2012 3:33 pm
lowrange have one for a vit box too dont they
Post Posted: Tue Sep 04, 2012 5:33 pm
I am sure I saw one there a year or four ago but there is only one for a Sierra box now.
How convenient Armsup
Post Posted: Tue Sep 04, 2012 9:31 pm
Hey Shep :)
http://www.puresuzuki.com/kick_pitman_arm.htm
Post Posted: Fri Sep 07, 2012 6:59 am
Thanks joe.
Vehicle: 92 tintop sierra
Post Posted: Thu Oct 18, 2012 4:46 pm
Acouple of q's.
Did you have to bend the metal sections of the vit high pressure hose or are they untouched.
Also where did you place the resivour?
thanks.
Post Posted: Thu Sep 05, 2013 1:00 pm
What do people do with the passenger side radiator mount now that the drivers side is spaced across?
Post Posted: Thu Sep 05, 2013 3:37 pm
And the fan now offset..
Users browsing this forum: No registered users and 13 guests
