It is currently Thu Oct 29, 2026 10:19 pm
Post Posted: Tue Sep 27, 2011 9:59 am
G'day everyone,
I'm in the process of lifting my 2000 Jimny with a 3" Jimnybits lift kit (and new radius arms). I've got some Kumho KL71's in the pipeline - 31x10.5 R15's.
I'm stumped trying to work out how much negative offset to go for though. From all the forum searches I've done it looks like most go for somewhere between -12 and -19 offset, sometimes more.
I will be building up some front and rear bars and extending the guards so I'm prepared for "body mods". I would also like to minimise the stability loss from raising the beast.
Any pointers appreciated!
Cheers,
Post Posted: Tue Sep 27, 2011 10:00 am
the WA jimny dudes are running 15x7 -13... smiffkid on here runs 31s - search the build threads and you should turn his up.
just b sure to take lots of pics :helloo:
Post Posted: Tue Sep 27, 2011 10:34 am
I am running -13 offset with 235 tyres and they sit just inside the gaurds. Minimal scrubbing. I am also running jb 75mm coils and it is stable. I was running 0 offset and it felt tippy.
I would look at running a -18 or so offset as you will be taller again with the tyres.
Post Posted: Tue Sep 27, 2011 11:50 am
but again his tyres wont be wider?? helping for stability?
does 31x10.5 will fit 15x7 rims.... or he's better with 15x8 rims?? ... that extra width wont mean a different approach for offset
Post Posted: Tue Sep 27, 2011 12:14 pm
15x8 -13 is 12mm bigger offset then a 15x7-13
15x7s are fine for 31s but u will want to do some floor mods to fit 31s with only 75mm lift
dodgy brothers mechanical
Post Posted: Tue Sep 27, 2011 10:40 pm
it looks like I can only get 15x8's with a -19 offset.
This is pretty close to what others run I think. I'm hoping there's not too much interference but I'll have to suck it and see.
Post Posted: Wed Sep 28, 2011 11:30 am
your obviously looking in the wrong place
can get 15x8s with a 0 -11 -13 -22 -35 and -50 with out going custom
there just the sizes i know of
like i said 31s with 75 mm lift
good luck to ya
Users browsing this forum: Google [Bot] and 308 guests
