It is currently Thu Jul 30, 2026 10:13 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
Post Posted: Fri Sep 30, 2011 2:00 am
Will a 2.0 litre 4 banger out of a Later Vitara bolt up to my AW4 Auto?
And could I use the same computer and wiring loom in my 93 EFI Vit?
Serious noises from my motor,
looking into engine options, now that I have to. :cry:
Post Posted: Fri Sep 30, 2011 3:51 am
Next questions.
Can I fit a coil pack type donk with my wiring,
or use my dizzy instead?
Or re use my extractors, manifold etc.
Vehicle: vitara
Post Posted: Fri Sep 30, 2011 3:55 am
Mate, crappy luck, cant help with the questions, but if you need a hand with anything.
Give me a yell.
Matt
Post Posted: Fri Sep 30, 2011 4:00 am
Give me a yell.
Matt
Thanks for that. Sand dunes will have top wait till next year.
Post Posted: Fri Sep 30, 2011 4:06 am
I would think that you could treat a coil pack motor like a Swift swap, change cam and rear housing, put your manifolds on and keep your ECU and so on, but would be better to hear from somebody that has done it
2l would be a no go though
Vehicle: 2001 XL7
Post Posted: Fri Sep 30, 2011 4:40 am
Is the 2.5 GV possible? Plenty of those at wreckers
Post Posted: Fri Sep 30, 2011 8:31 am
I don't really want that sort of power.
I don't think drive line is up to it?
Need reliability more.
I may just find a G16B has enough power, if its not worn out.
Not having ever driven a 1.6 it is hard to compare it to anything.
Some of the possible donks out there seem to be less powerful anyway.
May attempt a rebuild, but would prefer bolting in a complete engine.
Will investigate the noise more closely tomorrow.
Post Posted: Fri Sep 30, 2011 8:41 am
Give me a yell.
Matt
x2
I'm not working much, have a good set of tools and am ok on a spanner.
Post Posted: Fri Sep 30, 2011 8:49 am
what do the 2.5's go for? would prob just be better off buying a car that has one in it.
Post Posted: Fri Sep 30, 2011 8:53 am
shakes wrote:
Give me a yell.
Matt
x2
Thanks, will let you know if I need anything.
I prefer buying engines running in cars, or engines with warrantees.
Post Posted: Fri Sep 30, 2011 9:02 am
I love an engine swap but is it worth taking a look at the current motor first? What sort of budget do you have to work with? How soon do you need it back on the road?
Post Posted: Fri Sep 30, 2011 9:13 am
shakes wrote:
Give me a yell.
Matt
x2
I'm not working much, have a good set of tools and am ok spanner.
:lol:
yeh if ya need someone to stand there and point at stuff with a beer in his hand....lol
seriously if you need help speak up.
Post Posted: Fri Sep 30, 2011 9:15 am
Yes, I reckon its worth considering a set of bearings, or a kit, as there is no oil loss, smoke, or leaks and it has only lost a small amount of coolant.
Time is not an issue, as I am on a disability pension,
ie don't work, and public transport is close by.
But it has been a long build, I was hoping to start driving it more now.
Budget is close to zero now, have to save up again,
after buying the low range gears.
If I do a swap, will only be something that fits in with laws,
easyish to fit,
and don't need an engineers report.
Probably a fresher engine would have the power I desire anyway.
Have used jap import donks in the past, mostly very happy with,
but still a bit of a gamble.
Post Posted: Fri Sep 30, 2011 9:16 am
Built4thrashing wrote:
shakes wrote:
Give me a yell.
Matt
x2
:lol:
Thanks, I will do, cheers
Also there is not alot of difference between a J20a and a H25a..... both are up around the 100kw mark.
Easier to just get a change over motor if you happy with the power it had.
Post Posted: Fri Sep 30, 2011 9:18 am
I think this thread needs an injection of reality.
A replacement 16V 1.6 bottom end is both cheap and easy to get hold of. Last time I was at Imlachs there were about 7 of them there.
Any J, M or H series motor is going to be a huge PITA to swap, roughly as much hassle as a non-suzuki swap. Any of these motors will also require engineering approval.
Any non-suzuki engine swap will only be as good as the gearbox/transfer combination that can be used. An SR20, for instance, would require the construction of a hybrid silvia/skyline/patrol transmission using a patrol transfer... or something.
An ideal swap would be a 3RZ and auto from a hilux, but will it clear the front diff? do you have the money and nouse to convert to a gear drive transfer? ( all 3RZ autos were mated to chain drive transfers= no low gears)
I understand the desire for more torque at lower revs to counter the lack of diff gears for vitaras running big tyres, but I don't think it's feasible in your application Chris.
PS I think the most effective swap for a vitara is a 3.9 Rover V8, ZF auto and LT230 transfer.
Post Posted: Fri Sep 30, 2011 9:20 am
It felt powerful after a 1.3 carby donk.
But it may have never been full power, no idea.
I'll do quickest cheapest most reliable thing,
not want more garage time, its driving season
Post Posted: Fri Sep 30, 2011 9:25 am
Yes, with me, it always comes back to that.
Which is not necessarily a bad thing.
Not found any real viable options yet.
But reliability/cost is number one,
and easy cheap maintainance.
Post Posted: Fri Sep 30, 2011 9:30 am
There aren't any other than a fresher G16B. You already have a low geared transfer and an AW-4.
Post Posted: Fri Sep 30, 2011 9:36 am
I have learned from the interwebs that
later G16B are meant to have a better/stronger crank.
Not confirmed that yet.
But sounds like a bonus
Have found a few cheapish bottom ends,
but I dont know what head is like yet.
Hoping to change a whole motor, rather than rebuild.
But tomorrow I'll pull sump off and decide wether I can do a simple ring and bearing job, or not
Post Posted: Fri Sep 30, 2011 9:41 am
There's no such thing as a simple ring and bearing job. If its made enough noise for you to stop driving it you'll be up for crank grinding and you'll be on the merry-go-round of short life and multiple patch up jobs or more money in the motor than you've spent on the car to date.
Find a low KM G16 motor with decent compression and a head that passes a compression test. You don't need a better/stronger crank, you need an engine with bearings between the crank and the block. You're not going to turbo/supercharge/N02 it so what Suzuki thought it needed in the first place will be fine.
I'd use the newest baleno motor you can find.
Steve
Post Posted: Fri Sep 30, 2011 9:43 am
Baleno is coil pack. Chris's vit is dizzy
Post Posted: Fri Sep 30, 2011 9:45 am
shakes wrote:
Give me a yell.
Matt
x2
:lol:
I don't do much, But I do it well! :lol:
Post Posted: Fri Sep 30, 2011 9:53 am
So? That's just a cam swap - no need to separate black and head=win if the result is a newer, fresher motor.
I'd rather swap cams on a 2001 Baleno motor than fit a 1991 Vitara motor for the sake of a camshaft.
Post Posted: Fri Sep 30, 2011 10:00 am
This is roughly where my searching has lead me.
Wasn't sure if I could swap cam, and maybe sump,
like I did for Barina donk into the Sierra.
And those later model G16's would have the better crank as well.
There appears to be a G18 as well,
shares some components with the 2.o vit.
But not sure how many are around.
Not sure wether thats a realistic option yet,
as I need to stick with my extractors etc to save dosh and work..
(I just found head gaskets not same, so little chance 1.8 will share parts with 1.6)
Post Posted: Fri Sep 30, 2011 10:07 am
:blink: Really?
That's news to me. Never heard of it. US has J18 Vitaras though.
Post Posted: Fri Sep 30, 2011 10:11 am
There is a suzuki x90 i noticed on ebay in SE melbourne which has a G16B and AW4 the same as you already have. Possibly be good for parts or if you wanted the engine you could probably make some money back on the other parts. Its done a few k's but might suit as a plug and play temporary option and you could rebuild the original engine.
http://www.ebay.com.au/itm/suzuki-x90-v ... 049wt_1262
Post Posted: Fri Sep 30, 2011 10:12 am
:blink: Really?
yeah thats my confusion.
I think its just people getting things mixed up.
but worth a hunt
Post Posted: Fri Sep 30, 2011 10:16 am
christover1 wrote:
http://en.wikipedia.org/wiki/Suzuki_G_engine
but worth a hunt
Not more than 5 seconds worth:
Users browsing this forum: Google [Bot] and 61 guests
