| Author |
Message |
rpower10
Joined: Thu Sep 22, 2011 2:54 am Posts: 16 Location: Sydney
 Posted: Tue Oct 04, 2011 3:35 am |
Alright just wanted to make sure.. I'm running a pretty stock zook coily for adventure touring more than extreme 4x4.. For some reason I don't want to do a lift but will do all the shocks and springs done at stock height with some qual gear.. ironman or something. Anyways for my annoying question what tyres will fit under stock height plus without much gearing drama. I'm thinking on 15x7 rims.. 215 75 15 minimum.. so what's the maximum... don't want to cut or bash any bits. Cheers. Rob.
anto86
Joined: Sat Jan 01, 2011 8:35 am Posts: 100 Location: Gold Coast
Vehicle: SJ40T + Coily
 Posted: Tue Oct 04, 2011 3:52 am |
I don't know that you would get anything bigger than that under there. I have 235/75R15's with a 40mm lift and at full compression i get scrubbing on the front wheel arch. That's after having the seam hammered flat.
rpower10
 Posted: Tue Oct 04, 2011 4:31 am |
Okay .. thanks mate...scratch 235's then.
neofitou
Joined: Wed Mar 24, 2010 10:30 pm Posts: 1088 Location: Melbourne
Vehicle: 00 Jimny, 63 Haffy
 Posted: Tue Oct 04, 2011 4:35 am |
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Tue Oct 04, 2011 4:44 am |
A 215/80R15 definitely fits and is the largest tyre I would want on a stocker setup for touring.
IMO for a 235/75R15 to fit you'd want to look closely at rim offset. Coilys having a wider axle means a deep offset causes the fronts to rub as Anto86 described.
IMO 15x7s with small tyres isn't a good idea. Maybe get some 6 or 6.5" rims if you go to a 235. Stock WT rims offer a good offset if staying with 215s - A 215 will 'just' sit under the flare on a WT rim. Narrower rims are better IMO.
If you are after a quality lift, the Pedders 2" kit is pretty good IMO. I would never go to stock height again either - with a small front lift the extra tension put on the swaybar creates a really stiff front end which handles well IMO.
JrZook
 Posted: Tue Oct 04, 2011 5:50 am |
235's will fit with very very minimal work. No lifts required
_________________ Lil Foot!
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Tue Oct 04, 2011 5:58 am |
rpower10 wrote: I'm thinking on 15x7 rims.. 215 75 15 minimum.. so what's the maximum... don't want to cut or bash any bits. Cheers. Rob.
215's are too narrow for 7" rims. I'd be fitting 215's to the standard rims as there's quite a good range in that size. Any bigger and you really want to sort out gearing as it will suffer a bit on road.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Tue Oct 04, 2011 6:29 am |
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Tue Oct 04, 2011 7:10 am |
Scrawn wrote: rpower10 wrote: I'm thinking on 15x7 rims.. 215 75 15 minimum.. so what's the maximum... don't want to cut or bash any bits. Cheers. Rob. 215's are too narrow for 7" rims. I'd be fitting 215's to the standard rims as there's quite a good range in that size. Any bigger and you really want to sort out gearing as it will suffer a bit on road.
I ran 225's on standard rims and in that size i didnt even notice a difference in drivability.
Drova
Joined: Mon Aug 01, 2011 2:48 am Posts: 167 Location: Perth
Vehicle: 85 hightop drover
 Posted: Tue Oct 04, 2011 8:19 am |
x2 I also ran 225/75/15 on a 5.5" stock rim
For About a year, lots of 4x4 at 10psi
No problems at all!!
_________________ 16valve efi hightop drover
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Tue Oct 04, 2011 8:57 am |
my uncle has 215/75r15 BFG KM2 on his unlifted jimny... brand new they just scrub the back of the front guard, but after about a year of tyre wear they now just miss =P haha
his are also fitted to the stock rims.
sierra-morgs
Joined: Thu Aug 18, 2011 2:43 am Posts: 20 Location: Blue Mountains SYD
 Posted: Tue Oct 04, 2011 9:35 am |
i run 215 75 15, with a 2inch body lift but there would be plenty of room without the lift, and from what i hear thats about the largest you can go without starting to look at gearing.
rpower10
 Posted: Tue Oct 04, 2011 8:53 pm |
Hmm thanks for the info guys.. I'll look at the pedders but have read pretty bad reviews on them. Then again they'd prob be fine for my light track work. So I might scoot down there today and get a quote on say 40mm lift... then look at 15x7 with 225 75 15.. Sound doable and chunky enough? Cheers.
Reubs
 Posted: Tue Oct 04, 2011 9:07 pm |
rpower10 wrote: then look at 15x7 with 225 75 15.. Sound doable and chunky enough? Cheers.
What is the obsession with wide rims? Standard WT rims and a chunky 215 will sit in line with the edge of the flare on a coily.
The problem with 7" rims and 215s (or 225s even) is when you air them down there isn't sufficient pressure against the bead to stop mud/stones getting in there and deflating the tyre. There is also more chance of the bead coming of the rim. Then there is more rotating mass of a heavier rim, etc, etc.
6" is all you need LOL!
rpower10
 Posted: Wed Oct 05, 2011 12:34 am |
Cool! Thanks Reubs! Got my head around it now! That sounds like the solution.
