It is currently Wed Sep 30, 2026 11:18 am
Post Posted: Tue Oct 04, 2011 7:14 am
my key is in the ignition barrel and wont turn or come out. whats going on? how do i get it out?
Vehicle: Lwb Sierra
Post Posted: Tue Oct 04, 2011 7:17 am
hammer and chisel?
or
tried spraying wd40 and wiggling it around?
or worst case pull the cover off and hammer and chisel the factory headless bolts off, remove the barrel and see if that does it?
Vehicle: Yellow Ute
Post Posted: Tue Oct 04, 2011 7:19 am
Is the steering lock on and the wheel is held up against the wall of the lock? Gets me every time...
Post Posted: Tue Oct 04, 2011 7:20 am
Yep, penetrating oil and wiggle. You should be able to remove the barrel somehow
What car?
Vehicle: 02 jimny
Post Posted: Tue Oct 04, 2011 7:23 am
Happens to me every now and then try turning it backwards and wiggle vertically. That works for me
Post Posted: Tue Oct 04, 2011 7:24 am
sierra. steering lock isn't on. have dumped 1/2 a can of inox into it over the last week.
Post Posted: Tue Oct 04, 2011 7:26 am
is this your fire truck???
If so It's frucked... :helloo:
Post Posted: Tue Oct 04, 2011 7:28 am
Has it had any heat around it lately??? It might have fused together :finger: :finger: :finger: :finger: :finger: :finger: :finger: :finger: :peaceout: pompoms :steamroller:
Vehicle: 02 jimny
Post Posted: Tue Oct 04, 2011 7:29 am
How long was it in there for
LIVING LIFE ON THE EDGE, TILL YA ROLL
I have a key and lock set you can buy homo :)
Post Posted: Tue Oct 04, 2011 7:30 am
yeah its the burnt car. i hosed the barrel out and illed it with innox then put the key in and turned it past the steering lock.
went back to it 2 weeks later and it is locked up.
Post Posted: Tue Oct 04, 2011 7:31 am
which car... its not melted in there is it? (sorry, had to ask)
WD40 or Inox MX3 is fine for locks, DO NOT SPRAY OZSPRAY DOWN THERE!
Post Posted: Tue Oct 04, 2011 7:34 am
i have never even heard of ozspray :wink: lock didnt even get warm however
would have coped a dose of dry powder, i am sure i held the gurni on it for a minute or so.
Vehicle: LWB Sierra & XL7
Post Posted: Tue Oct 04, 2011 7:35 am
I had a similar problem with this corolla I have.
The key was that worn away that I could remove the key with the car still running, one day it decided not to come out and it wouldn't turn at all, I sprayed WD into it but still nothing.
Then I got thunking on how the ignition barrel or pad lock works, obviously pins have to move in in order for it to work. I pushed up and it slid out after a couple of jiggles.
I got a new key cut but still had the same issue, obviously the new key was based on the worn key.
Again, wouldn't come out or anything. After about an hour of fart arsing around I ended pushing the key up and managed to turn the barrel to ign, at that point I had pretty much most of the steering column pulled apart. A quick Youtube lerned me how to remove the barrel. just a matter of pushing in a pin with the right size centre punch out out it slid.
I replaced the barrel along with the door locks to suit the same key.
I hope this trick helps you out.
Post Posted: Tue Oct 04, 2011 7:39 am
try a bit of heat on it
Post Posted: Tue Oct 04, 2011 7:41 am
He should probably leave heat alone for now don't ya think? :D
:blink:
Post Posted: Tue Oct 04, 2011 7:50 am
Shep does not know what a bit of heat is :wink:
Post Posted: Tue Oct 04, 2011 8:14 am
Ozspray (or Candan industries) is a lanolin based product much like Inox, except this stuff, also known as woolube, goes tacky and sticks rather than staying like a lubricant.
its a fantastic rust inhibitor
Post Posted: Tue Oct 04, 2011 8:17 am
oohhhh crap. i did give it a spray with a lanolin based marine corrosion inhibitor.
stick ya tongue out the left side of ya mouth, then try.... :roll:
Post Posted: Tue Oct 04, 2011 8:44 am
when we remove this stuff, we put it through a parts washer.. maybe try some wd40 down the guts of it, it may of gone all tacky
Post Posted: Fri Oct 14, 2011 7:49 am
key now works. i dumped 1/2 a can of contact cleaner into the barrel and then 1/2 a can of wd40
and got cranky with some vise grips.
works like a new one except there is now no steering lock.
Post Posted: Fri Oct 14, 2011 8:04 am
Ruff bastard :wink:
Users browsing this forum: Google [Bot] and 122 guests
