It is currently Mon Sep 21, 2026 2:31 am
Post Posted: Sat Sep 03, 2011 7:31 am
Not yet it is but it can be with YOUR help :helloo:
Youll see I made an index of how to threads here
http://auszookers.com/index.php?name=Fo ... ic&t=25384
I would like to make an index of all the threads here in good tech but ive had my fit of useful for a few months so wish to farm it out
So would some people like to help me out here? just make a url link by clicking the Image in the reply window, paste in teh thread link and type in teh thread title
If people are interested just post in here where you are going to start from (say page 2 from the bottom working up) and start sticking them in a post then reply in here.
They dont have to be in order as they will move anyway and I will leve them in your post so the world will know how awesome and helpful you are
Post Posted: Wed Oct 05, 2011 2:51 am
Thanks for all your help, great bunch of community you are
Vehicle: 4wd
Post Posted: Wed Oct 05, 2011 3:38 am
Auszookers Needs You!
Generic
Generic - Soldering Tech 101
Generic - The Trailer Thread
Generic - DIY Sand Flag
Generic - Spot Light Wiring
Generic - How To Replace Diff Oil
Generic - Falcon Alternator Upgrade
Generic - Gearing Numbers And Calculations
Generic - Alternator Replacement
Generic - Engine Oil Change
Generic - CB Radios
Generic - Valve Stem Replacement And Bead Cleaning
Generic - How To Paint Wheels
Generic - Megasquirt
Generic - Mini Spool Installation
Generic - Tyre Puncture Repair
Generic - Basic Chain Axle Puller
Generic - Queensland Transport Modification Guidelines
Generic - The Locker Bible
Generic - V6 Vitara to Hilux transfer swap
Generic - Alternator Failure Diognostics
Generic - Drive Shaft Balancing Information
Generic - Air Locker Air Line Repair
Generic - Shock Sleeve Removal
Generic - Broken Bolt Removal
Generic - Welder Mega Merge Thread
Generic - Plastic Headlight Restoration
Generic - Axle Widths
Generic - Air Filters
Generic - ARP Wheel Stud Upgrade
Jimny
Jimny - g13bb 120amp Alternator upgrade
Sierra
Sierra - Hilux Diff Modification
Sierra - G16B Guide
Sierra - 4k Corolla Carby
Sierra - Hub Rebuild
Sierra - Windscreen Replacement
Sierra - VSS ~ Another VSS
Sierra - Rear Disk Conversion
Sierra - SJ410 Master Cylinder Rebuild
Sierra - J20 Engine Conversion~ More Information Here
Sierra - How To Undo Door/Body Screws
Sierra - Baleno G16B (Coil Pack) Conversion
Sierra - Fuel Tank Float Fix
Sierra - Longer Leafs
Sierra - F10 Gear Box Options
Sierra - Factory Rear Locker
Sierra - Rear Up Front (Springs RUF)
Sierra - Spartan Locker
Sierra - Roctoy Ring Pictures (FAB)
Sierra - Sway Bar Removal (Leaf Sprung)
Sierra - Vitara Power Steer Install
Sierra - Water Pump Information 1.3l
Sierra - LJ80 Gear Box Fail
Sierra - Cressida Power Steer
Sierra - 1.3l Injection Conversion
Sierra - 1.3l Carby Re-Jetting
Sierra - gearbox sensor ID
Vitara
Vitara - Changing Front Wheel Bearings
Vitara - Changing Timing Belt G16A
Vitara - CV Rebuild
Vitara - Compression Test G16B
Vitara - Roof Racks
Vitara - Power Window Switch Fix
Vitara - Camber Bolt Install
Vitara - Rear Brake Drum Removal And Fitment
Vitara - Commodore Shocks~ Fitting Commodore Shocks
Vitara - Installing Front Struts
Vitara - Front Brake Upgrade
Vitara - SQ625 Speedo Correction
Vitara - SV620 Brake Change
Vitara - Under Bonnet Checks 1.6l
Vitara - GV Free Wheel Set Up
Vitara - Bullet Proof Front Diff
Vitara - Sierra Spartan Locker Installation
Vitara - Bump Stop Extensions
Vitara - Repairing a manual window regulator
Vitara - G16B Clutch Fan Oil Refil
Vitara - Trimatic Transmission Service
Vitara - Diff Ratios
X90
X90 - Late Model G16 Dizzy With Integrated Coil
X90 - Mini Spool
Watch out or you'll get sued.
Post Posted: Wed Oct 05, 2011 3:44 am
just spotted this post :oops: will try and work out the clicky post stuff. :helloo:
Vehicle: 4wd
Post Posted: Thu Jan 19, 2012 9:07 pm
Up to date index: viewtopic.php?p=470747#p470747
Post Posted: Thu Jan 19, 2012 9:35 pm
If you edit it after my post, it will say you edited it.
Edit* No worries. :lol:
Post Posted: Thu Jan 19, 2012 10:08 pm
you broke the internet :(
do you have them stored anywhere? break them up into a series of noew posts and ill delete the old posts
Vehicle: 4wd
Post Posted: Thu Jan 19, 2012 10:11 pm
Post Posted: Thu Jan 19, 2012 10:14 pm
the whole lot might be too much for a single post, try jsut putting the sierra ones into a post
Vehicle: 4wd
Vehicle: 4wd
Post Posted: Thu Jan 19, 2012 10:16 pm
Post Posted: Thu Jan 19, 2012 10:29 pm
what does it say?
can you email em to me and I will try?
Post Posted: Mon Jan 30, 2012 11:07 am
Testing Links
Generic
Generic - CB Radios
Jimny
Sierra
Sierra - G16B Guide
Sierra - J20 Engine Conversion  ~  More Information Here
Vitara
Vitara - CV Rebuild
Vitara - Roof Racks
Vitara - Commodore Shocks  ~  Fitting Commodore Shocks
X90
X90 - Mini Spool
Post Posted: Mon Jan 30, 2012 12:45 pm
There was some broken ones...fixed...
The photos are broken in the "Generic - Engine Oil Change" thread though.
Generic
Generic - CB Radios
Jimny
Sierra
Sierra - G16B Guide
Vitara
Vitara - CV Rebuild
Vitara - Roof Racks
X90
X90 - Mini Spool[/quote]
Post Posted: Mon Mar 25, 2013 11:54 pm
Jimny - M13a VVT Alternator Upgrade
Jimny - OffRoadArmoury WT Transfer Case Swap
Jimny - Diff Breathers
Jimny - Roof Racks on non-factory equiped Jimny
Sierra - Transfer case rebuild/Gearing upgrade (LROR PDF)
Jimny - Shitload of VERY useful how-to PDF'S shamelessly linked from BigJimny
MY BUILD THREAD HERE!!!!!
Users browsing this forum: No registered users and 160 guests
