It is currently Wed Oct 07, 2026 5:35 am
Post Posted: Thu Oct 06, 2011 3:41 am
Hey Guys/Girls,
I'm keen to find out what rev range you guys go through on your Sammys.
Mine is a 1988 model Samurai (SJ50) with a G13a 1324cc with timing set at 11 degrees running 95 - 98 octane. I've owned it for over a year now and dont seem to have too many issues with it (weekend warrior for hunting) but I've always thought that it revs a bit low. I feel i'm going to blow the bugga up if I take it much more than 4200 - 4500rpm in any gear. Being a small engine I would have thought it would rev freely to easily 5 - 6k like a toyota.
Keen to hear how everyone else's goes.
Cheers,
Grant
Post Posted: Thu Oct 06, 2011 3:50 am
Stock engines are rated for maximum hp @ ~6500rpm. Shouldn't have much of an issue revving up to that
Lil Foot!
Mine used to rev to about 8000 but the motor was very loose. The new one i put in, would easily rev to 6000 and could be pushed to 7000 but it didnt sound as happy.
Post Posted: Thu Oct 06, 2011 3:54 am
thanks for the quick replys. I must have an issue somewhere, just not sure where. Seems to go alright, just not rev happy.
Post Posted: Thu Oct 06, 2011 3:57 am
mine used to go to 6000-7000 pretty easy but is getting pretty tired so i am trying to keep it around 4000-5000 till it gets a rebuild.
Post Posted: Thu Oct 06, 2011 4:01 am
Dunno what carb is on yours but a common issue here is the vacuum secondary throat not opening.
Lil Foot!
Vehicle: Ducati Monster
Post Posted: Thu Oct 06, 2011 4:02 am
^^ mine was the same till i chucked a weber on it
Post Posted: Thu Oct 06, 2011 4:14 am
Standard one. Thanks for the suggestion, i'll have a read through the FSM in regards to the vacuum secondaries.
Thanks
Vehicle: 96 sj70+80 tintop sierra
Post Posted: Thu Oct 06, 2011 5:49 am
Mine wasn't sounding to happy above 5500. Just before rebuild managed a over 7000 line locker. Lasted a minute and ended with cracked piston skirt. Still drove it smokey for a few days...
Post Posted: Thu Oct 06, 2011 5:56 am
that would have been nice to see :lol:
Post Posted: Thu Oct 06, 2011 5:57 am
Having a look through the FSM, is the above your talking about the secondary throttle valve? can't find any reference to a secondary throat.
Post Posted: Thu Oct 06, 2011 6:19 am
Wasn't to bad. Looked like a magna or excel under load. Still heaps of power too. :twisted:
Post Posted: Thu Oct 06, 2011 6:20 am
That would be correct. Look for the vacuum actuator and check for leaks. Then check the vacuum line to it for leaks and see if it's clear of carbon right through the carby port.
Lil Foot!
Post Posted: Thu Oct 06, 2011 6:28 am
cool, thanks :)
Post Posted: Thu Oct 06, 2011 6:36 am
my g16a is happy at 6500rpm too! :)
Post Posted: Thu Oct 06, 2011 9:09 am
yeh my g16a revved easy to 6000+ and was happy as... then i got the g16b and babied it for ages not going over kinda 4500-5000... but of late i've been giving it a hiding and it loves it. Theyre supposed to have a rev limiter but i've not found it yet.
Post Posted: Thu Oct 06, 2011 9:27 am
my 16v g16 does 7k very easily, cant wait to stick it in my sierra
Vehicle: 2018 DMAX
Post Posted: Thu Oct 06, 2011 9:37 am
Need to try harder, mine loves been on the limiter. Even the g13 I had loved to rev past 6k.
Post Posted: Thu Oct 06, 2011 9:58 am
Nothing quite like using valve bounce as the limiter :D
Vehicle: 85 hightop drover
Post Posted: Thu Oct 06, 2011 10:05 am
A g16b at 6800rpm is better haha
16valve efi hightop drover
Post Posted: Thu Oct 06, 2011 12:59 pm
Really pointless in a stock G16b. Makes good power till about 6000rpm then tapers off pretty quickly
Lil Foot!
Post Posted: Thu Oct 06, 2011 1:17 pm
hahahah the toyota carola hire car we had n sydeney last we loved is rev limiter. 6500. wasnt till we dropped it of that we were told it only had 500 kms on the clock when we picked it up! OOPPS!
THINKING BEFORE POSTING!!!
Post Posted: Thu Oct 06, 2011 5:39 pm
the odometer usually tells you.
Post Posted: Thu Oct 06, 2011 9:50 pm
Mine pulls all the way to limit, that's
With extractors! Your motors probably
A little loose
Post Posted: Thu Oct 06, 2011 10:32 pm
A little loose
With 200odd psi of compression and extractors I don't think so, neither do the peps that have taken it for a spin.
Maybe my butt dyno is a lot less loose and more configured than yours :wink:
Lil Foot!
Post Posted: Fri Oct 07, 2011 12:43 am
What's the timing set to BTDC' ?
Post Posted: Fri Oct 07, 2011 1:41 am
11 degrees. Now i'm literally going away for the weekend after this post and wont be able to check replys till sunday night but i have a question and it may be stupid :oops:
If the bonnets up and i play with the accelerator control and open her up, should i see the secondary acctuator move? my thoughts are yes, but it doesn't. So the issue would lie there?
Cheers all and have a good weekend
Post Posted: Fri Oct 07, 2011 1:48 am
Yes it should move open, on rapid
Acceleration, high rpm
Post Posted: Fri Oct 07, 2011 1:52 am
A little loose
His drova absolutely smashes shit and sounds good bouncing the limiter :D
JrZook What's your timing set to BTDC' ?
Post Posted: Fri Oct 07, 2011 2:16 am
Drova wrote:
A little loose
Around 10 with the diag connector bridged. It's on the safe side, anymore and she will start to ping. They are not as rev happy as the 1300's. The power peaks at 6000RPM compared to 6500RPM of the 1.3's. This is pretty noticeable.
grunta:
It's a vacuum actuated secondary setup, hence it will only come on at high loads and throttle inputs. You would be lucky to see it move just free-revving. To see it it moves attach a loose cable tie or something onto the shaft and go for a hard drive. You will know its its working cause teh cable tie etc would have moved.
Only other way is to check to actuator/vacuum hoses/carb port for leaks or clogging.
Dan
Lil Foot!
Users browsing this forum: No registered users and 172 guests
