| Author |
Message |
mud-skippa
Joined: Wed Jan 19, 2011 6:41 am Posts: 17 Location: roxby downs
 Posted: Fri Oct 07, 2011 9:18 pm |
hey guys just wondering if a transfer from a w/t will fit in a n/t
thanks jarrad
607CHA
Joined: Thu Apr 07, 2011 8:21 pm Posts: 265 Location: Baldhills
Vehicle: 02 jimny
 Posted: Fri Oct 07, 2011 9:22 pm |
I think you'd have to change the flanges? But people 1ltr transfer in 1.3. So I don't see why not. I could be wrong
_________________ LIVING LIFE ON THE EDGE, TILL YA ROLL
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Fri Oct 07, 2011 9:26 pm |
607CHA wrote: I think you'd have to change the flanges? But people 1ltr transfer in 1.3. So I don't see why not. I could be wrong
Spot on mate
_________________ Shep is a closet jimny lover!!!!
weaves
Joined: Fri Mar 21, 2008 10:30 pm Posts: 1564 Location: Newcastle
 Posted: Fri Oct 07, 2011 9:28 pm |
Plus your NT will most likely have the handbrake on the back of it.
_________________ I'm Weaver & i like beer, boobs, cars and stickers
Jackson
Joined: Mon Apr 04, 2011 5:56 am Posts: 559 Location: Newcastle
Vehicle: Yellow Ute
 Posted: Fri Oct 07, 2011 9:30 pm |
If it is the NT without a 4x4 switch is it you can't put transfer gears in it but your can swap the flanges or you can't do both?
89_tintop
Joined: Fri Aug 07, 2009 11:30 pm Posts: 3159 Location: gold coast
 Posted: Fri Oct 07, 2011 9:41 pm |
Jackson wrote: If it is the NT without a 4x4 switch is it you can't put transfer gears in it but your can swap the flanges or you can't do both?
You cant do both.. To make it work you have to run a modified shafts
foolsp33d
Joined: Tue Mar 11, 2008 10:30 pm Posts: 2123 Location: Deep Inside Jamies Mouth
Vehicle: Clown Car..
 Posted: Fri Oct 07, 2011 10:00 pm |
modified being a NT/WT shaft, but with the 1.0(smaller PCD-non swithced) flange at the xfer end. the switched 1.0 xfer off memory will use the standard NT flange... that makes sense right!?
_________________ Roads... Where we're going we dont need Roads....
89_tintop
 Posted: Sat Oct 08, 2011 1:25 am |
Yeh ... Makes sense to me ...
