It is currently Tue Oct 13, 2026 7:28 pm
Post Posted: Sun Oct 09, 2011 6:35 am
Hey guys was searching the web for info on alternator convertions for a 1.3 sierra when i came across this...
http://cgi.ebay.com/ebaymotors/ws/eBayI ... =WDVW&rd=1
From what i see it's far easier than a falcon convertion but couldn't find much info on guys in australia useing this kit. Just wanting to know what peoples thoughts are?
Post Posted: Sun Oct 09, 2011 7:51 am
Looks alright dude.
Pro - You get a Brand new Altenator with the kit
- its a bolt on package by the look of it.
Con - Its about 3 times the price of a Falcon Alt conversion.
Stocker
Post Posted: Sun Oct 09, 2011 7:52 am
I have this on my 91 swb and its working great, been on about 6 weeks no problem.
Post Posted: Sun Oct 09, 2011 7:54 am
That kit looks pretty good, but..................
Replacing that alt won't be easy locally if you get it full of mud..
It retains a V belt.... I had to go to multirib on my falcon alt as a V belt can't take the load needed to make 100+ amp.
US$229 plus freight will make it near enough to $300 by the time you get it....
A lot cheaper to do an EF falcon alt conversion.
Post Posted: Sun Oct 09, 2011 7:55 am
Looks pretty beaut to me, will the small A section belt work ?
but it's not really more $$ then the falcon convertion if you concider it's a brand new alternator
High Top Drover
Post Posted: Sun Oct 09, 2011 7:58 am
Brand new EF alt....
Post Posted: Sun Oct 09, 2011 7:59 am
the cs 130 alt are available in oz, not sure of cost but they are available if you need to replace them.
Post Posted: Sun Oct 09, 2011 8:05 am
Ok i see yer point The falcon is cheeper then i thought. but from what i've read the is alot of work and mucking around to get the falcon alt to fit.
I'm not planing to sink my alt in mud either.
So would the falcon alt be worth the trouble? or would i be better off with something like this?
High Top Drover
Post Posted: Sun Oct 09, 2011 8:07 am
cs130 seems like a pretty generic alternator for GM vehicles. Lots of parts and variants on eBay.
You can pick them up as cheap as the new falcon ones. $130 landed out of the states (new).
Lots of upgrade kits available to if you find 105amps isn't enough :lol:
I guess if the V belt didn't hold you could chuck a serpentine one on. Lots of pulleys available for them off eBay.
Post Posted: Sun Oct 09, 2011 8:12 am
What about the wiring bit he was on about, plugs straight in, where as you need to do shit with wires to get the EF to work.
Post Posted: Sun Oct 09, 2011 8:15 am
Yer it was more the simplicity of this convertion that i was attracted to
High Top Drover
Post Posted: Sun Oct 09, 2011 8:16 am
there are 2 wires, if you get them wrong nothing happens and you swap them over, shit you could leave the engine running while you do it
trying to drive that much with a V belt is a good point, you start winding up the belt tension up and you are putting more load on the alternator and water pump bearings
Post Posted: Sun Oct 09, 2011 8:22 am
sorry im still new two all this. so what would be a better option than a v belt?
High Top Drover
Post Posted: Sun Oct 09, 2011 8:25 am
multi rib, like every non-ancient car has got
Vehicle: Zookless
Read this Timmay :P
http://auszookers.com/index.php?name=Fo ... pic&t=5529
Post Posted: Sun Oct 09, 2011 8:47 am
Ok thanks guys. I'm still not 100% on what i'm going to do at this stage but i will do a bit more research?
High Top Drover
Post Posted: Sun Oct 09, 2011 9:05 am
CairnsZook:
i have just read that link but im still confused. If i do the falcon alt, what pullys will i need? It seems every bodys useing diffrent pulleys?
High Top Drover
Vehicle: Zookless
Post Posted: Sun Oct 09, 2011 9:11 am
Not sure mate, I've got a 1.6 so all my pulleys are ribbed anyway.
You'll have to swap yours to be ribbed like the alternator.
Post Posted: Sun Oct 09, 2011 9:33 am
Ok no prob mate.
Dose anybody else no what the best pulley set up would be?
High Top Drover
Post Posted: Mon Oct 10, 2011 12:27 am
Nice name :P
Post Posted: Mon Oct 10, 2011 12:50 am
I would also like to see an alternator put out 100+ Amps on a V belt.
As royce stated it would lead to one over tightening the belt and causing premature bearing failure.
Multi Rib belts have far more surface area in contact with the pully and therefore do not slip under higher loads like the V belts.
Stick with the EL alternator and get the right pulleys and you'll be laughing.
Post Posted: Mon Oct 10, 2011 4:01 am
I have done a bit more research into the GM cs130 alt and it's a Small high output alt and it's not much bigger than the standed 1.3 alt. Because of the size would the v belt still be an issue? There seems to be a few guys in the US that have them with out any trouble. Or would i just be better with the falcon alt?
High Top Drover
Post Posted: Mon Oct 10, 2011 4:51 am
GM sounds like the way to ... buy it, put it on and give us feed back!!!
Post Posted: Mon Oct 10, 2011 4:59 am
its more to do with the horespower required to spin it at full load, which will be twice as much as the stock alternator
Now being that its unlikely youll ever get the thing making 100 amps (batteries dont really charge much higher than 30 amps) it will never be a problem, but if you were using it a lot (lots of lights or similar) youd notice the slipping
Post Posted: Mon Oct 10, 2011 5:48 am
Well im planning on runing Driveing lights, rear work light, led intirior lights, a winch and wanted to put in a bigger battery. I wanted the alt to be able to Charge the larger battery with out the risk of the battery dieing in the ass due to alt not being able to keep up.
I'm still tempted to get this kit and see how it gose, but on the other hand i dont want to go spending money on somthing thats not going to due the job.
At this stage i think the Falcon alt convertion is looking like a better option.
High Top Drover
Users browsing this forum: No registered users and 249 guests
