It is currently Tue Sep 29, 2026 3:14 am
Post Posted: Tue Oct 11, 2011 2:47 am
Will a vitara clutched engine fan (viscous fan) fit strait on a 1.3 sierra engine and is there much modification to make it fit advantages and disadvantages plz
92sierra ht 33s 5in lift 2in zorst gti powered
Post Posted: Tue Oct 11, 2011 5:40 am
And can I run my 1.3 shroud
Vehicle: 4wd
Post Posted: Tue Oct 11, 2011 5:42 am
Someone like gwagon will be able to fill you in.
But I believe it will fit and that you can use the shroud. And its win win.
Watch out or you'll get sued.
Post Posted: Tue Oct 11, 2011 6:03 am
Yes and sort of.
It is a 100% bolt on. It might brush your fan shroud, so you might want to modify the shroud a little. I've only ever fitted them to non-1.3 sierras (1.6's and 660) but I reckon with a 1.3 it might actually just clear the shroud with no mods.
It's the single biggest cooling upgrade you can do to a sierra. It's such a cheap, easy and effective modification.
Steve
Post Posted: Tue Oct 11, 2011 6:10 am
Ahh ok thanks how much am I looking around and if I do need to adjust the shroud how will I go at it
Post Posted: Tue Oct 11, 2011 6:13 am
I am looking at doing the el alternator upgrade this weekend along with a vitara fan and maby a thermo
Post Posted: Tue Oct 11, 2011 6:19 am
A bit of heat, maybe a strip of thin aluminum to open it up a bit- whatever works. Just don't cut the shroud away, it defeats the purpose.
Post Posted: Tue Oct 11, 2011 6:27 am
Yes and sort of.
Steve
I'm liking you lately Mr G.... :P
Vehicle: 07 vvt jimny
Post Posted: Tue Oct 11, 2011 6:36 am
steak_knife wrote:
Yes and sort of.
Steve
sounds like a proposal could be on the way soon aye ;);)
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Tue Oct 11, 2011 6:42 am
I propose Mr G build's a car that's not ugly!!!
:P
Post Posted: Tue Oct 11, 2011 10:20 am
Ok thanks heaps I am going to get an viscous fan on the weekend I will do that along with my el alternator
Post Posted: Tue Oct 11, 2011 12:04 pm
:P
Says the guy who owns Buttercup? :P
Piggles looks awesome! :D
Post Posted: Wed Oct 12, 2011 5:31 am
sideways wrote:
:P
:? What did want33s say??? :?
Post Posted: Fri Oct 14, 2011 12:02 pm
I went to the wreackers today and picked up a Jimmy engine fan it is a viscous fan that has seven blades and is just smaller than the vitara one by mm and fits strait on with no cutting of the shroud looks Really good and goes good
Post Posted: Fri Oct 14, 2011 12:03 pm
It is off the older jimneys not the newest one
Post Posted: Fri Oct 14, 2011 7:01 pm
Armsup
Al tho the vit hub last's longer, but the difference will be very noticeable...
Armsup
Users browsing this forum: No registered users and 166 guests
