It is currently Thu Sep 24, 2026 12:44 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
Post Posted: Tue Jan 11, 2011 6:09 am
canberramav wrote:
No
$3000 is for supply of ECU and wiring it up and then tuning it.
Canberra is always expensive.
Ok.
Thats about right then.
Post Posted: Tue Jan 11, 2011 6:16 am
What about Wolf3d v3.1.
Can get this for good price. $400
Post Posted: Tue Jan 11, 2011 7:43 am
i had a microtech on my old turbo 1.3 it did the job and i had no problems with it. i think it was a lt4 or some thing like that. tune was just one for a gti engine. easy to play with. i got it 2nd hand so have no idea about tech support.
how much boost you looking to run? you thought about getting the stock ecu looked at and bigger injectors? if your keeping it under 7 it will be pretty safe
Vehicle: I drive your mum
Post Posted: Tue Jan 11, 2011 8:26 am
Stock ECU with bigger injectors will overfuel at low load situations. Dont do a half arsed job, at least run an interceptor and set it up properly. But bigger injectors would be a pretty good idea.
Layto.....
Post Posted: Tue Jan 11, 2011 8:39 am
thats why he would need to find out if some one has the tuning program for the stock ecu.
on a side note flash tuners don't let you play with the pulse rate of the injectors. they will let you do nearly every thing else. i just found out the costly way and now have to take my car to a tuner or fork out a stupid amount for the software. any one know a good tuner for xr6t on the central coast, newcastle or sydney?
Post Posted: Tue Jan 11, 2011 8:47 am
Black Track at Thornton have done a few from memory.
Layto....
Post Posted: Sun Jan 16, 2011 11:55 am
FYI
I picked up my Haltech E6K S/Hand from Boost losers for $500
and paid approx $700-$800 for an awesome tune from P.I.T.S. on the gold coast.
$3000 sounds like hiway robbery
Post Posted: Sat Jan 22, 2011 4:53 am
Ok guys
Got myself a Haltech E8 ECU.
Im a fair way off putting this on so ill update my build thread with any useful info about the turbo conversion.
Post Posted: Sat Jan 22, 2011 3:31 pm
canberramav wrote:
Ok guys
Nice choice, the Haltech E8 should do you well.
Layto....
Post Posted: Sat Oct 15, 2011 10:10 pm
Hey all.
Was wondering if you guys know where i can download a G16B base map for an adaptronic ECU... i haven't yet bought the ECU so i don't know which one it'll be yet. G16B is SOCH 16V, twin coils (waste spark), year unknown.
I'm no professional and i've never claimed to be.
Any help appreciated :)
Post Posted: Sun Oct 16, 2011 1:34 am
for that sort of money you could get a motec fitted.
i was quoted $4000 fitted and tuned. i was told by many you wont find a better ECU.
Vehicle: '96 LWB trayback
Post Posted: Sun Oct 16, 2011 2:44 am
Howie: If you email Andy Wyatt from Adaptronic (contact details are on the adaptronic forum - adaptronic.com.au) he will be able to assist you with a base map.
Matty: While motec has models with the widest range of options, most of them are completely useless on a road going car. Features like independent tweaking per injector is total overkill for all of us here.
For ~$2k, an Adaptronic (or most other ecu's) will achieve identical performance with an adequately skilled tuner.
Post Posted: Sun Oct 16, 2011 3:18 am
Phucking champion :)
Post Posted: Sun Oct 16, 2011 3:21 am
canberramav wrote:
Thanks for the info guys.
Just went to local tuner who is the dealer for Haltec. Im looking at $1650 for a ecu and to have it supplied and fitted then tuned was going to be up near $3000!!!
Bloody hell im in the wrong business.
The reason im considering the Microtech is they are cheap and i dont need the best of the best as it is only going into my comp truck.
The local bloke sells Microtech as well and thinks it is ok.
I just dont know now. I didnt anticipate this kind of expense.
I've run tens in my microtech powered rx7. Have a few cool upgrades on it for the injector cycle and how it comes in, very simple to use. Wouldn't worry about using another ecu. And yes my rx7 was daily driven. Been in a work shop for a while getting cool beans added to it.
Users browsing this forum: Google [Bot] and 149 guests
