It is currently Mon Sep 21, 2026 7:03 am
Vehicle: 1995 Suzuki Vitara JX LWB G16B
Post Posted: Fri Oct 21, 2011 8:48 am
hi i need to take my sierra back over the pits on the 30th and one of the listed problems is the leak between the reservoir and the master cylinder, i first looked at getting an entire new set, but then saw seal kits kit 1 kit 2 they are severely cheaper than the entire reservoir and cylinder package at $245 and i only get paid once between now and then and to be honest can't afford the seal kits, so any saving helps, i have no idea which kit to buy and i don't know if the included gaskets and seals would stop the leak between the reservoir and the cylinder, suzistore could really say either way either,
so if anyone can look at those pics and see something that they know would fix my leak that would help heaps,
also when under my zook recently i saw what seemed to be a brake bias thingo or proportioning thing i dunno what it's called but it had a bleed nipple on it, i need to install a new rear hardline on the back right hand side and will then need to bleed the brakes, does this thing on the chassi rail with the nipple on it need to be involed too?
thanks in advance guys
-AJ
89 Sierra (Crashed)
95 Vitara (Current)
Users browsing this forum: Google [Bot] and 178 guests
