It is currently Sun Oct 25, 2026 5:53 am
Vehicle: LPG 1.6 Sierra
Post Posted: Sun Oct 23, 2011 8:56 am
I'm wanting to adjust the idle screw on my new throttle body, but it won't budge... it's well and truly locked with this white stuff. I have the right key/bit (whatever it's called) but i'm giving now up before I strip the thread.
Any tips to get it free?
Post Posted: Sun Oct 23, 2011 8:58 am
flatten two sides and use vice grips to turn it?
Vehicle: '96 LWB trayback
Heat the shit out of it. The glue will release/soften.
butane torch or a jet lighter git some direct heat on it & give it a shot
Post Posted: Sun Oct 23, 2011 9:09 am
x2
Post Posted: Sun Oct 23, 2011 9:13 am
undo the lock nut on the base of it?
Post Posted: Sun Oct 23, 2011 9:17 am
correct by the looks of it! :lol:
Undo the but 1st, Its a lock nut. The paint might be just a marking to say its tight.
Post Posted: Sun Oct 23, 2011 9:42 am
A lock nut? :? :roll: totally missed that - i'll give it a try when i'm back home later
Post Posted: Sun Oct 23, 2011 10:00 am
need to get it over 60 degrees and the locktite or thread lock will release doesnt sound like much but the metal will absorb most of the heat
rust is lighter then carbon fiber
Post Posted: Sun Oct 23, 2011 11:51 am
The paint's there to say, " set by factory, don't f*#k with me"
Just make's adjustment's easier to find... :roll:
Post Posted: Sun Oct 23, 2011 8:40 pm
:lol:
Can't even spell nut properly.. undo the but 1st..
Those markings are everywhere on a jimny..
Post Posted: Sun Oct 23, 2011 9:09 pm
:lol:
wouldn't know, never seen under one of them ting's.... :roll:
Post Posted: Mon Oct 24, 2011 7:19 am
Cunnava thing - the nut is recessed and my 8mm socket is too thick for the gap, and my spanner is too straight to get a bite on it. Time to bang things :evil: :evil:
Post Posted: Mon Oct 24, 2011 8:46 am
Thats not an idle screw . its a throttle stop screw , its there to stop the butterfly from fully closing and jamming in the housing. If you adjust it , you will also need to recalibrate the tps . you shouldnt need to adjust it , you should have an idle air bleed screw there somewhere to bleed air from before the throttle body to raise the idle.
Post Posted: Wed Oct 26, 2011 6:26 am
Lpg, doesn't need the Tps...
Post Posted: Wed Oct 26, 2011 9:37 am
ahuh , well in that case ...
a little bit of heat usually sorts any threadlocker out ...
