It is currently Fri Oct 30, 2026 12:35 pm
Post Posted: Mon Oct 24, 2011 3:25 am
Old vit motor has these bits, but new Swift Baleno doesnt.
Don't want to crack open crank bearing bolts if I don't have to.
Anyone know what they are for?
Post Posted: Mon Oct 24, 2011 3:29 am
They are bearing cap stiffeners. Better to leave if possible
Looks like bracing for extra strength. I'd put it on the new motor if it fits, stronger is better :D
Post Posted: Mon Oct 24, 2011 3:34 am
Yeah I think I just decided to change them over to the new donk.
Gone to so much trouble to get everything else right,
may as well put them in.
Now to look up torque setting for crank bearing bolts.
I better check bolt length, too, in case they different
crank girdle
Post Posted: Mon Oct 24, 2011 3:35 am
It is called a stud girdle and is A GOOD THING... Helps to stop the main caps and block webbing from flexing. Block/cap flexing is A BAD THING.
Post Posted: Mon Oct 24, 2011 3:36 am
crank girdle
Does that make it a girly car then :D
Post Posted: Mon Oct 24, 2011 3:39 am
Thanks all, it will be going onto the new donk for sure.
Wouldn't fit without the sump change.
Forgot to buy a sump gasket,
so its all tomorrows job now
Post Posted: Mon Oct 24, 2011 3:54 am
http://www.suzimotive.com.au/technical.htm
Found a useful listing of torque settings and other useful info.
Is it the Main bearing torque figure I'm to use?
Post Posted: Mon Oct 24, 2011 4:01 am
Yep, those are the main bearing caps.
Post Posted: Mon Oct 24, 2011 4:10 am
Thanks muchly.
Post Posted: Mon Oct 24, 2011 8:39 am
personally , i wouldnt worry too much about the girdle . Have built a 1.6 engine that has been running progressive power figures since 2006 without a girdle .
2006-2008 .. 118 hp n/a
2008-2010 .. 128.3 hp n/a
sept 2010- june 2011 206hp turbo
june 2011 210hp turbo
has just had another $8000 spent on the engine , still no girdle ...
expecting to make 250hp plus atw (over 310hp at the flywheel)
only failures in the last 5 years have been detonation (aggressive tuning)
Post Posted: Mon Oct 24, 2011 8:54 am
I have an unfortunate reputation as an engine killer.
Going to try real hard to keep this one alive for a long time.
I can't see the girdle doing any harm,
so I will stick it in, it is easy job anyway.
I was just surprised,
first I seen or heard of them.
Could be a Vit thing?
Post Posted: Mon Oct 24, 2011 1:06 pm
mate, make sure you use a torque wrench that is calibrated, i have to calibrate mine at work every 6 months. wouldnt be expensive to take it to a shop that could calibrate it.
i have seen some very expensive torque wrenches (norbar, snap-on, cat etc) go out of calibration by a long way in 6-12 months.
Post Posted: Mon Oct 24, 2011 5:57 pm
Yeah the bracing I switched it over to my baleno block too, hey extra stiffness cam only be a good thing
Post Posted: Mon Oct 24, 2011 7:47 pm
At my age that is very important :wink:
Post Posted: Mon Oct 24, 2011 7:48 pm
Going to use thread locker, too, to be sure.
Post Posted: Mon Oct 24, 2011 8:02 pm
Be aware thread lock could give you a false tension reading, usually the numbers will be based on a certain fitting condition, IE dry or oiled etc
I wouldnt use it, if a bolt were to come loose by itself something else is gravely wrong
Post Posted: Mon Oct 24, 2011 8:06 pm
Good point,
haven't used it anywhere else on the job,
found no evidence of its use in the old engine yet.
And is especially nasty when trying to get stuff off.
Post Posted: Mon Oct 24, 2011 9:54 pm
I am a big fan of using it correctly on the bottom pulley bolt as flogging the keyway there is a problem, but you should be ok everywhere else
Post Posted: Mon Oct 24, 2011 9:59 pm
Had no reason to touch that, but have heard its an issue.
I try not to disturb things if I can, but will do that I think.
I got some gasket maker for sump,
auto shop found no gasket listed,
only a recommended gasket maker.
So hope its good enough.
Post Posted: Tue Oct 25, 2011 5:00 am
A warning note for anyone doing sump related things.
With no gasket, and using a sealer instead,
my bolts were too long for some of the holes.
2 snapped off :( but a lot of swearing and a dremel,
all was cool again.
(So glad I bought that thing, used 3 times on engine jobs already)
So a 5 minute job took all arvo. Nothing new there.
So engine is ready for fitting now, I think.
Post Posted: Tue Oct 25, 2011 6:59 am
Chris how could the auto shop not find a listing for a sump gasket?
Are they retarded or just on drugs?
1.3 Sierra/Swift is same gasket as 1.6 Vitara/Swift/Baleno.
Post Posted: Tue Oct 25, 2011 7:08 am
No idea, maybe he meant none in stock,
I mishear sometimes,
not that I'm worried,
never used a diff gasket,
or even a water pump gasket for a long time.
Though I noticed new engine had no sump gasket.
Just something red.
Most bolts were fine,
just 4 down each side, don't have a hole right thru.
Post Posted: Tue Oct 25, 2011 7:27 am
no 1.6 suzuki engine ever came from factory with a sump gasket , all were sealed with silicone/threebond
Post Posted: Tue Oct 25, 2011 7:34 am
My import donk had a red sealant only.
My dead Vit had a cork gasket, and some black shit as well.
The dead one wasn't the oiriginal motor,
so probly explains that.
In my day we went to the cupboard
and cut a gasket out of weet bix packets.
And used stuff called gasket goo, that was used with a gasket, too.
Cheers.
Post Posted: Tue Oct 25, 2011 7:50 am
This is exactly how the oil filter housing on my mini is sealed, but I used cornflakes
Post Posted: Tue Oct 25, 2011 7:54 am
Thats clearly of higher quality :goodjob:
Post Posted: Tue Oct 25, 2011 9:02 am
And people complain of Chinese products using cardboard or Coke cans for winch drum gaskets...
2002 SWB GV
Lifted and Locked
Post Posted: Tue Oct 25, 2011 10:09 am
But we only use high quality Coke cans and Cardboard
Users browsing this forum: Google [Bot] and 288 guests
