It is currently Tue Oct 27, 2026 3:32 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Post Posted: Wed Oct 26, 2011 12:30 pm
Ok so i know NOTHING about vehicle electrics...
how do i put a rear LED spotlight on a switch? (step by step including parts needed).
Cheers =)
Post Posted: Wed Oct 26, 2011 12:37 pm
Cheers =)
get light, rest on top of switch, done
Post Posted: Wed Oct 26, 2011 12:38 pm
I'd just run it through a switch, wouldn't pull enough to warrant a relay?
Post Posted: Wed Oct 26, 2011 5:19 pm
x2 mines just hooked up to a switch no relay.
Vehicle: 1985 Holden Drover
Post Posted: Wed Oct 26, 2011 7:31 pm
Sweet so when I do my rock lights I won't need another relay to add to my shot fight next to the battery :)
1989 WT Sierra.
Post Posted: Wed Oct 26, 2011 7:45 pm
http://www.auszookers.com/index.php?nam ... c&p=477427
only for LEDs, halogen lights should really be on a relay
Post Posted: Wed Oct 26, 2011 9:27 pm
cool, cheers =)
Post Posted: Thu Oct 27, 2011 8:09 am
ok i thought i had it right in my head and now im second guessing myself...
i've got all the wire, connectors and an inline fuse holder (ill put a 10a blade fuse in it cos i've got tons of them). The switch is a standard on/off toggle switch (2 poles).
can someone please show me a diagram of how i run the wires? lol im useless at electrics so the more simpleton the better.
I'm just going to run it straight off the battery so it can be on whenever i want, not on ACC or the reverse switch etc...
Vehicle: LPG 1.6 Sierra
Post Posted: Thu Oct 27, 2011 8:21 am
Behold... I hope it's right, someone can chime in if it's wrong
Post Posted: Thu Oct 27, 2011 8:27 am
so i join my pos and neg on the spotty wires to the cable length of pos & neg, run cable to switch and split to pos and neg on switch, new cable from back of switch - pos to battery and neg to the body?
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Oct 27, 2011 8:33 am
Yep with a fuse close to the battery
Post Posted: Thu Oct 27, 2011 8:36 am
single wire from positive battery terminal into fuse, out of fuse to switch, out of switch to the back and onto the positive wire on light (might be white) then the remaining earth wire from the light atach to teh body or one of the black earth wires already up the back for the tail lights
thats it
Post Posted: Thu Oct 27, 2011 8:40 am
Gimmie a holla if you need a project supervisor Aron, i'll pop around and lend a hand :helloo:
thanks royce... so no need for running both wires up to the cab, i like it.
Post Posted: Thu Oct 27, 2011 9:07 am
gonna do this hopefully this weekend ive had a led work light ofr months now just didnt know how to wire it up cheers.
Post Posted: Thu Oct 27, 2011 9:39 am
Thanks mate, i'll call if it doesnt work haha =) i got a start on it tonight - got the fuse connected to the pos battery terminal and a female connector on that, and the first wire through the firewall with a male connector... will knock the rest out in the morning cos the mozzies were about to carry me away out there!
Post Posted: Thu Oct 27, 2011 12:23 pm
crimps 8O
use solder.
i hate crimps!!!! with a passion
THINKING BEFORE POSTING!!!
Post Posted: Thu Oct 27, 2011 1:10 pm
im using solder and crimps =)
im crimping the connections then taping them.. anything that i splice (ie: the wire i got the pos off the battery) i've soldered... so the fuse wire is soldered to the battery essentially... after that there will be crimpage, but i'll be taping the connectors as i join them to keep them as protected as possible.
its only a rear light anyway... if it goes bad theres only a couple of joins to check.
Post Posted: Fri Oct 28, 2011 2:24 am
get glue shrink and put it over you crimps, theyl never come undone then!
its like heat shrink but has glue in it aswell that melts when u heat it up, makes it 100% water tight, and helps hold everything together! you can get it at jacar!
Post Posted: Fri Oct 28, 2011 5:54 am
SSSIERA wrote:
crimps 8O
use solder.
Solder sucks ballz.
Learn how to crimp properly and use a decent crimper.
2002 SWB GV
Lifted and Locked
Post Posted: Fri Oct 28, 2011 6:20 am
twist and tape 8O
Post Posted: Fri Oct 28, 2011 6:33 am
MrRocky wrote:
twist and tape 8O
so you've worked for autobarn/strathfield's :lol:
Post Posted: Fri Oct 28, 2011 6:50 am
TheOtherLeft wrote:
SSSIERA wrote:
crimps 8O
use solder.
Solder sucks ballz.
I find a combo of things work well. First crimp the wire and have a little wire poking out the end of the crimp, solder that to the crimp and heat shrink it all.
Post Posted: Sat Oct 29, 2011 12:16 pm
TheOtherLeft wrote:
SSSIERA wrote:
crimps 8O
use solder.
Solder sucks ballz.
Solder has it's place....
But x2 on getting a good pair of crimps....
Post Posted: Sat Oct 29, 2011 12:22 pm
monkey wrote:
TheOtherLeft wrote:
SSSIERA wrote:
crimps 8O
use solder.
Solder sucks ballz.
i got decent crimps and one of them flash ratchet crimpers. but my soldering skills are supurb so crimps are a thing of the past!
Post Posted: Sat Oct 29, 2011 12:25 pm
bullshit, you just enjoy sniffing lead fumes...
Post Posted: Sat Oct 29, 2011 9:43 pm
Solder has mechanical issues as it creates a solid length of wire (however short) which due to vibration can break. Crimping keeps the wire relatively flexible at the join.
I have decent soldering skills as well but crimp instead. I sometimes crimp but then just put a very small amount of solder on the exposed bit of cable.
2002 SWB GV
Lifted and Locked
Post Posted: Sun Oct 30, 2011 3:47 am
Who doesnt :lol:
Post Posted: Sun Oct 30, 2011 4:31 am
Its funny how people think soldering is a better option, any good auto or aircraift electician will tell you that solder is rarely used in automotive, marine or aircraft rewires or accessories.
Users browsing this forum: No registered users and 296 guests
