It is currently Tue Oct 27, 2026 8:09 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
Vehicle: LPG 1.6 Sierra
Post Posted: Sun Oct 30, 2011 4:42 am
^^^ That's good to know - something i'd never have guessed. So really, just a crimp and a bit of heat shrink should be enough?
Otherwise if it's joining two lenghts i'm guessing you just twist the wires together and shrink it tight?
Post Posted: Sun Oct 30, 2011 4:55 am
For joining 2 wires together in a permanent connection I do solder them, but then I use a couple layers of heatshrink for strength. Granted it's not the best as connectors should be used but meh...
2002 SWB GV
Lifted and Locked
Post Posted: Sun Oct 30, 2011 6:32 am
2stroker wrote:
Its funny how people think soldering is a better option, any good auto or aircraift electician will tell you that solder is rarely used in automotive, marine or aircraft rewires or accessories.
Do you know how much of this I have cleaned from crimps in 4wd's? both botched up blue crap things and factory crimps.
http://en.wikipedia.org/wiki/Verdigris
Not to mention when it corrodes the wire away totally leaving you with no connection
Solder fixes this wonderfully as is seals the join with lovely corrosion free lead and tin, you would have to be pretty ham fisted to solder and secure a loom poorly enough that vibration might make it fail, indeed I think any kind of crimp terminal available to most people here would vibrate loose in the same conditions
Post Posted: Sun Oct 30, 2011 6:55 am
Had a quick thought today that crimps and other connectors also add a bit of weight to the wiring hence vibration could cause more problems over the soldering option.
2002 SWB GV
Lifted and Locked
Post Posted: Sun Oct 30, 2011 6:57 am
That would describe a lot of home mechanics...
2002 SWB GV
Lifted and Locked
Users browsing this forum: No registered users and 256 guests
