It is currently Wed Oct 28, 2026 5:06 am
Post Posted: Sat Nov 05, 2011 5:45 am
I've got a stock SWB vitara and I'm going to be adding the following over the next few weeks:
2" Body Lift
30mm/15mm Coil Spacers
Ironman Extended Rear Shocks
Stock LWB Vitara Coils - Same length as SWB, but thicker.
1.5" Front Strut Spacers
Strut Mount Flip
Just wondering if I should be adding extended brake lines to that list? The BL instructions have rotating the brake line (something, I forget the part) to face down to give them some more room, but I'm wondering if that will be enough.
Any advice appreciated, cheers.
Post Posted: Sat Nov 05, 2011 6:08 am
mate there a good idea but not critical, i run 2"body + 2"sus with commo shock in my vit and im still running stock length brake lines. it is on the list for new ones but its not urgent.
Post Posted: Sat Nov 05, 2011 10:59 am
That's awesome news, thanks! Just saved me $200. I'll keep it in mind if I come into any spare cash, though. Cheers.
Post Posted: Sat Nov 05, 2011 11:00 am
I didn't need extended brake lines.
I got 50mm BL, 50/25mm coil spacers, 40mm + struts and strut flip.
But just cross it all up and see if brake lines are too tight.
Don't go too long, either, or they can get caught more easily on stuff.
With strut spacer, coil spacer and a strut flip,
you will start straining your cv's,
and could be close to full stretch on brake lines?.
Post Posted: Sat Nov 05, 2011 9:25 pm
If I've got the Strut Spacers bought already, do you think it'd be worth just canning the strut mount flip for a later date if needed?
If that would save the CV's a little, I'd be fine just using the spacers.
Post Posted: Sat Nov 05, 2011 9:32 pm
That would be my choice
Post Posted: Sat Nov 05, 2011 9:34 pm
i have a pair of new unfitted diff drop brackets :wink: make a offer if ya want them
Post Posted: Sat Nov 05, 2011 9:49 pm
Brakelines shouldnt cost that much!
Last time i got some for a sierra, $35 each..
Post Posted: Sat Nov 05, 2011 10:03 pm
$75-100 plus postage to 6025 :D
Users browsing this forum: Google [Bot] and 268 guests
