It is currently Fri Oct 30, 2026 6:48 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
Post Posted: Wed Nov 02, 2011 6:21 am
trying to fit this to the front ofmy 90 model tin top wt http://www.ebay.com.au/itm/DIFF-LOCK-SP ... 0650491618 i dont have the 3 pin part and the square bit with the 4 spider gears are they.. have i got the wrong locker excuse the laymans terms mine is just 1 pin with 2 spider gears :blink: says it fits any 1.3 leaf sprung sierra
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Wed Nov 02, 2011 6:54 am
Put up some pics!
Sounds like you've got an unusual diff there, I think the vitara ones are like that, Christover managed to get his together if this is the case as he put the Spartan in the front of his vit.
Also, you got jacked if you paid that price.
http://www.lowrangeoffroad.com/index.ph ... uzsam.html.
I had the Spartan front and rear in my Sierra.
Vehicle: 1985 Holden Drover
Post Posted: Wed Nov 02, 2011 6:55 am
Yeha man i saw this one on ebay and then i just checked low range, even with delivery its like $100 less still :?
1989 WT Sierra.
Post Posted: Wed Nov 02, 2011 7:29 am
Your front diff is the two pin. So you will need a 4pin and put it up front.
But you should be sweet to use it with the two pin centre if you can find a pin block to hold the washers in place.
Or just put it in the rear. I have the same locker in the rear and it's awesome.
Post Posted: Wed Nov 02, 2011 7:33 am
they were right. It will fit in any1.3ltr leaf sprung sierra diff. it will even work in a single pin diff but you need the cross pin block to hold the side gears apart. I know a few sierras that run a lockright in the same diff as yours....
Post Posted: Wed Nov 02, 2011 7:36 am
ok so the (2 pin) is that just one pin straight through? cause that is what is in there! so i need a new diff center? would be alot stronger with the right diff yeah?
Post Posted: Wed Nov 02, 2011 7:38 am
That's the 2pin yes. You can get a 4pin centre. Or get a pin block from a 4pin centre and it will work.
Post Posted: Wed Nov 02, 2011 7:48 am
so would it be weaker with the 2 pin? an you wouldn happen to know where i might source one of those blocks? an is this a sierra diff center or somethin else? :blink:
Post Posted: Wed Nov 02, 2011 8:00 am
Yes, but I wouldn't worry about it. You'd break a CV before the centre I'd say. I think shep has a 2pin locked front.
You could get it from a 4pin diff. So any rear diff and older fronts. But if you're looking for a centre to get the pin, you might as well use the whole thing. Depending on when you need it I could pull a diff apart and send it to you. But I don't have much time till after the weekend.
Post Posted: Wed Nov 02, 2011 8:05 am
ok so do you think the back is the same or would it be the 4 pin? so you got one for sale dan? no rush might just put it back together do another day!
Post Posted: Wed Nov 02, 2011 8:12 am
The rear is a 4pin and will go straight in. I have the same locker in the rear of mine.
I can send you a pin block next week if you need it.
Post Posted: Wed Nov 02, 2011 8:21 am
yeah well im going to need one by the looks
Post Posted: Wed Nov 02, 2011 8:52 am
yeah had this same convo with shep, he is running a 2pin diff with a lockrite locker.
oi dan, how many of those pin blocks you got ? ill take one aswell if you got it ? what sort of price ya after ?
Post Posted: Wed Nov 02, 2011 8:56 am
Only one left I'm willing to part with I'm pretty sure mate. Sorry.
Post Posted: Tue Nov 08, 2011 4:29 am
ok so ive fitted the spartan locker to the front diff into the 2 pin carrier and just used the square block out of a rear diff that had a 4 pin carrier but when you lock the hubs and try to turn left it just clunks and it does the same thing to the right but only just turns to the right.. :blink:
Post Posted: Tue Nov 08, 2011 6:18 am
I'd give it time to bed in, should free up.
Mine was like that at first.
Did you make sure that you removed the thrust washers,
as they can hide in the grease and crud.
If they still in there, locker can't unlock.
Post Posted: Tue Nov 08, 2011 6:25 am
Why didn't you use the 4pin carrier?
PS. Some people have had to trim down the pin block,
to get locker to work,
is rare, but can happen.
To unluck properly,
there needs to be enough space for locker to slide away from side gear,
Hence need to make sure original thrust washers are not stuck to the gears or centre.
And why some have needed to trim down the block.
Post Posted: Tue Nov 08, 2011 6:26 am
Methinks he only got the pin block, not an entire diff ??
Post Posted: Tue Nov 08, 2011 6:31 am
To unluck properly,
I still run the thrust washer's & linished the block, work's perfect..... :helloo:
Post Posted: Tue Nov 08, 2011 6:39 am
I just give it to the X-Spurts, so much easier!
Post Posted: Tue Nov 08, 2011 6:43 am
you paid for something??? 8O
Post Posted: Tue Nov 08, 2011 6:47 am
:thefinger:
:no: It's not what you know, it's who :wink:
Post Posted: Tue Nov 08, 2011 7:10 am
yeah removed thrust washer and didnt use the 4 pin cause it was out of the rear think it said sj50 said on the diff center and front axles was to small for it..
Post Posted: Tue Nov 08, 2011 8:27 am
yeah removed them..
and did yours not let you turn right at all cause thats what mine is doing 8O
Post Posted: Tue Nov 08, 2011 8:32 am
it was out of a rear diff center and the side gears was to big for the axle and the side gears out of the 2 pin wouldn fit in cause they were to big.. grr :evil:
Post Posted: Tue Nov 08, 2011 8:34 am
To unluck properly,
ok i'll have to pull it out and see whats going on in there..
Post Posted: Tue Nov 08, 2011 8:35 am
Occassionally it would not let me steer,
usually during 3 point type turns.
A quick left right on steering usually freed it up.
Doesn't do it now.
I remember during my instal,
1 of the tiny pins was a bit tight,
think that was my cause.
You either have to give it time,
or pull it out and double check everything.
Whatever you feel is right.
If you pull it out,
make sure locker has enough room to unlock,
Post Posted: Tue Nov 08, 2011 8:39 am
Post Posted: Tue Nov 08, 2011 8:43 am
Doesn't do it now.
If you pull it out,
ok well i can turn the left fine but it make a really bad
crunchin clunkin noise then when you go to turn it back
its really hard and wont even really turn to the right..
might just pull apart and have another look how do i know
if its got room to unlock?
Users browsing this forum: No registered users and 304 guests
