It is currently Wed Nov 04, 2026 1:23 pm
Post Posted: Thu Nov 10, 2011 12:57 am
My 1991 suzuki Vitara has got 2" suspension lift and its about to get 2"body lift.. Will 31" tyres fit i have done some research and found nothing helpful!!! I am getting the tyres off a friend who just upgraded to 33's i knw that i have to get a special rim(already ordered) and flares(also ordered) help me??
Vehicle: LWB Sierra & XL7
Post Posted: Thu Nov 10, 2011 1:04 am
Yes they will, but you will need to cut the guards a bit for them to clear.
As for rims, I recently purchased -23 offset which clear the chassis quite well. Rubber flares can be purchased from clark rubber and will keep those pesky coppers happy.
Here's mine.
3"suspension + 2" body lift. I have to pursuade my guards with a hammer just a little for them clear properly because they scrub on the plastics when flexed up.
Depending on the offset of your new wheels, they should fit, but you may need to hammer the seams in the wheel arch flat, and possibly trip the inner guard area at the base of the firewall.
It has been done plenty of times, so you should be able to get them underneath....
Post Posted: Thu Nov 10, 2011 1:06 am
yep 31's will fit, depending of the offset of the rim you might have to trim the metal work at the back of the front wheel arch in the inner guard area.
edit: way tooo slow :oops: :lol:
Vehicle: SJ50 hardtop!
Post Posted: Thu Nov 10, 2011 3:16 am
I cleared 30s on standard vitara rims with a 2" body lift, no hammerings etc, so I cant see why not.
NT SJ50
Post Posted: Thu Nov 10, 2011 3:21 am
The bigger the offset the more they hit
Post Posted: Thu Nov 10, 2011 4:48 am
not enough offset and they will hit the chassis, you can chop the guards but you can't chop the chassis.
Mine with 30's and 0 offset f100 sunnie rims, no chopping was required at all.
'92 Vitara & Camper trailer
Post Posted: Thu Nov 10, 2011 7:51 am
this is mine on 31's, 2" sus and 2" body lift. fitted 1.5" bumpstop ext. in the rear. mine are a -13 or so. stick out almost 2"
^^^^ can see where it was rubbing pryer to fitting bumpstops. havnt had a chance to take it bush much, but doesnt scrub to bad.
Post Posted: Thu Nov 10, 2011 8:07 am
no body lift, 2" spacers bump stop spacers in the front and a grinder had 15x7 -25's with the claws now on 15x8 -23's
if you do the hagan mod you would go close to not needing a hammer on the front at all
Users browsing this forum: Andygoodbloke and 112 guests
