[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
BlueSuzy
 Posted: Mon Nov 14, 2011 1:09 am |
Hi all.
Im currently converting my Sierra to a lux ifs box, (lux diffs etcetc) I am wondering what pumps everyone is using?
I think i need a Toyota pump with Multiv pulley. Is there such a thing? Will make engineering easier as then its all Toyota..
I also have a AU Falcon pump,mulitv, well known for their leaks, and are common, But will there be enough pressure for the lux box? I have seen one run with a cruiser box, but still unsure.
But what have others run?
Other info: G16b efi Suz motor, Lux diffs, 35"s. Minimal offset rims
Thanks for any help.
royce
 Posted: Mon Nov 14, 2011 1:13 am |
lots of buggy guys up here run modded falcon pumps and seem to do ok, they are the older type with the tank built in though
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Mon Nov 14, 2011 1:18 am |
The polyvee pullied falcon pumps we've played with have been nothing but trouble - belt slippage has been the biggest issue. I think both guys that set up on them down here have gone back to vitara.
(that's with a vitara box)
BlueSuzy
 Posted: Mon Nov 14, 2011 1:20 am |
Mine has the tank built in, Tear drop shape. From memory its off an Au?
It has a 6pk pulley but will only be running a 4pk belt. A Jim ac compressor will also be on the same belt with a seperate idler/tensioner
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Mon Nov 14, 2011 5:53 am |
Falcon pump will run a lux box no problems.
Even better if you mod it for increased flow/pressure.
BlueSuzy
 Posted: Mon Nov 14, 2011 7:17 am |
Cool. I will mount it and test it then. Mod if needed later.
Thanks guys
[ 6 posts ] |
Users browsing this forum: No registered users and 182 guests
