It is currently Fri Sep 04, 2026 4:54 pm
Post Posted: Sat Jan 03, 2009 1:00 am
Was bored this arvo so I went out to tinker with my zook I had a new cooler/warmer in my gararge that has been sittin there for about a year I tryed it in behind the seats and fitt good except for the drop in the tunnel so I decided to make a cradle to sit it in.
this is the cooler
I measured the cooler and cut some alloy angel up to suit
then I sat it all together to see if it fit
it fit well so then I drilled and pop rivet it together
then I cut some bits of the alloy to go on the corners
my cooler has rounded corners so I had the pop rivets facing in for looks
next I needed some legs to support it where the tunnel drops I bent a bit of alloy up and pop riveted it into place
I tryed it in the zook fit good the gave it a lick of paint
then once dry I screwed it down into place and fitted the cooler
all up took about a hour and a half to make nice and easy
hope this helps some one
cheers jimbo
 Profile YIM
Post Posted: Sat Jan 03, 2009 2:10 am
ah nice work. that looks neat. hows it feel getting your drinks in and out?
Post Posted: Sat Jan 03, 2009 2:24 am
nice job jimbo. things you do when boredom sets in. is it run of 12v cigarette lighter or 240v power.
Post Posted: Sat Jan 03, 2009 2:36 am
its not to bad to reach and yes its a 12v cig liter socket
 Profile YIM
Post Posted: Sun Jan 04, 2009 2:38 am
Nice job. Looks like I started something. Lol!
Post Posted: Mon Jan 05, 2009 5:16 pm
These are bloody handy things, Had one mounted in my cruiser for over 2 years. Gets used to keep the frothys cold sometimes and others to heat or keep my pies warm or heat the bottle for the youngn. Top work
Post Posted: Mon Jan 05, 2009 8:48 pm
Go that bit extra and go buy a 12v oven from Dick Smiths, so you can have a cold beer and a hot pie all at once whilst on the move. I have a similiar sized Waeco and 12v Oven both sitting behind my seat in my work van and couldn't do without them now.
Post Posted: Tue Jan 06, 2009 1:33 pm
hmm.. I have actually had one of the 12v ovens for nearly 7 years. Used to use it extensivly when 4wd in winter, dont use it much since putting the fridge/warmer in. To tell you the truth I dont drink that much anymore, much easier not to if you dont have any coldies either :wink:
Post Posted: Tue Oct 20, 2009 11:47 pm
i have a the same size in the waeco cost me 100 buck and i want to try and fit it between seat but i cant do that with out a bit of cutting on one of the seats does any one ave any suggestions
Vehicle: 1995 soft top vitara
Post Posted: Thu Nov 19, 2009 3:19 am
how well does the cooler work? i have the exact same one sitting in the my zook, i put it in there last week but havent had the chance to give it a run.
turbo vitara, fark yeah.
Post Posted: Sat Jan 09, 2010 2:46 am
there ok as long as what you put on there is already cold
its no longer in there as it dosent fit with the new seats
 Profile YIM
Users browsing this forum: No registered users and 20 guests
