It is currently Sun Oct 18, 2026 10:43 pm
Post Posted: Thu Nov 17, 2011 7:55 am
Fitting new tyres on GV steel rims - and the tyre guy reckons that one of my rims is buckled.
Only way they could tell was when balancing the tyres - needed 200g of weights to get it to balance.
Is it possible the tyre itself is that far off balance? As the rim 'looks' to be fine
edit - new tyres are KM2's in 225/75/16
My Grand Vitara
Post Posted: Thu Nov 17, 2011 8:31 am
They would of mentioned ( if they had a brain ) seeing it wobble, lot's of mud tyre's need lot's of weight...
Post Posted: Thu Nov 17, 2011 8:39 am
Get them to spin the rim up without the tyre on it and watch for warp. I have a Steel rim here that is buckled that badly the machine comes up with ERROR but t the eye it's hard to tell. Most probly come off a car thats been rear ended.
Post Posted: Thu Nov 17, 2011 9:00 am
I dropped off the rims this morning before work, and i'm going there tomorrow morning.
Just had a quick chat on the phone with them today, so i'll ask them to spin the rim without the tyre, and maybe even swap that tyre with one of the other ones. Should be able to tell if it's the tyre or the rim then.
If it is the tyre, 200g still sounds like alot. I know muddies are harder to balance but they wouldn't be that much off would they?
My Grand Vitara
Post Posted: Thu Nov 17, 2011 9:13 am
A tyre of that size shouldnt shouldnt need anymore than 100g. If the tyre is that bad then i'd ask for another.
If they have trouble balancing it up make them turn the tyre so the yellow dot on the tyre is in line with the valve stem on the rim. this is so the balance points match up.
Post Posted: Thu Nov 17, 2011 9:19 am
Cheers will do.
Hopefully it is the tyre and not the rim
My Grand Vitara
Post Posted: Thu Nov 17, 2011 10:57 am
KM2's are pretty bad for balancing, 1 of the 6 i have here (to durnk to pull the rest down to have a look what's on them) has 120g on it and Alien has a few weights on his too
Post Posted: Fri Nov 18, 2011 5:39 am
Turns out the rim is definately buckled. Not happy. :evil:
On the machine you can clearly see the rim wobble left/right a good 5mm.
The 3 other tyres took about 60-70g to balance.
I bought 4 rims off ebay and painted them up. Now i have to paint up my spare and use that instead. Will leave the buckled one sitting on the back door.
My Grand Vitara
Post Posted: Fri Nov 18, 2011 5:45 am
did you buy these rims....
remydog05 wrote:
steak_knife wrote:
http://www.ebay.com.au/itm/SUZUKI-SIERRA-VITARA-ROCKY-4-16INCH-WHEELS-AND-TYRES-/320705827417?pt=AU_Car_Parts_Accessories&hash=item4aab8e9259
Gv wheel's in Melbourne
Prick! This bloke bought these of me really cheap and is know on this site.
They are not in good condition and the tyers are shagged, and one of the rims is bent! All he has done is painted them.
If you are buying them please look at them first!
http://auszookers.com/index.php?name=Fo ... ent#398087
Post Posted: Fri Nov 18, 2011 5:53 am
Yep i guess thats them!
even knowing that the rim is bent - you still can't tell till its on the machine. The tyre sits properly on the rim, and its prefectly round. Where the wheel nuts go must be slightly off, but i cant see where.
oh also i got them very cheap! made an offer off ebay.
Whats a little wierd is that it turned out to be this guy. It hit the news just a few days after i picked them up. I'm still half expecting a call from the police :?
http://www.theage.com.au/victoria/polic ... 1nm4t.html
My Grand Vitara
Post Posted: Fri Nov 18, 2011 6:01 am
8O so this rock spider is an auszooker?
Post Posted: Fri Nov 18, 2011 6:25 am
8O That's fucked 8O 8O
Post Posted: Fri Nov 18, 2011 6:53 am
8O
So who is it??
I want my old sig back :(
Post Posted: Fri Nov 18, 2011 8:32 am
Ben_Sierra wrote:
8O
So who is it??
No idea. I could describe his zook and i'm sure someone here will know who it is.....but that could lead to 4000+ auszookers going after him :lol:
My Grand Vitara
Post Posted: Fri Nov 18, 2011 9:18 am
Nar we won't go after him...
Not sure we want child molesters in our online community either though...
Post Posted: Fri Nov 18, 2011 12:05 pm
These may be the rims I looked at buying off here but he was asking far too much for them. I'm sure I have the pm still if anyone is interested.
Post Posted: Fri Nov 18, 2011 12:42 pm
buckled rims can be fixed- there are several mobs over here that do it.
should be someone over your side that can sort it out- but no idea how cost effective it is.
stephen.
Post Posted: Sat Nov 19, 2011 9:51 am
stephen.
There is a place in Preston that re-roles rims...I have used them before but I cant remember their name.
If you're interested in having a look at it, I'll dig up the contact detail's.
If your not breaking shit, try harder!!!
Post Posted: Sat Nov 19, 2011 9:56 am
Just remembered it ...
Nuway Wheel Repairs
11 Beatrice Ave
Heidelberg West.
03 9457 3141
http://www.newaywheelrepairs.com.au
Post Posted: Sat Nov 19, 2011 10:26 am
Cheers Mugwui good to know 8)
Also found a couple of other places so i'll be making some phone calls during the week.
My Grand Vitara
Post Posted: Sat Nov 19, 2011 11:27 am
Most new tyres these days have balance spots on them to assist in reducing the weights required to balance a wheel, but most tyre fitters can't be arsed taking the time and just whack on heaps of weights and hope to get a near-enough balance. I've had one wheel where the fitter had put nearly 220g of weights around one side, and when I pointed out the dots on the tyre and requested he re-fit the tyre, the balance weights reduced to 10g!! He had no idea about them.
The YELLOW dot on a tyre is the lightest part of the tyre and should be placed nearest the valve stem.
The RED dot is the highest point of the tyre (in an out-of-round sense), and if the rims are marked with a WHITE dot (Signifying low point), the red and White should be nearest to each other.
Obviously, in most cases it will be impossible to have both the Yellow dot near the valve AND the Red dot near the White on the rim, and it is usually best to go for remedying out-of-round (red to white) and then add the amounts of weights required for balance, but some brands of rims don't feature the White dot mark and you go with Yellow to valve for best balance.. Sometimes too, with even the best matching, a rim and wheel combination will still require a lot of weights for a balance.
And sometimes your rim could be buckled too!
Users browsing this forum: No registered users and 259 guests
