It is currently Sun Oct 11, 2026 8:24 am
Post Posted: Sun Jan 04, 2009 4:16 am
Finally got around to doing a service on the zook, just an oil & filter change. I cracked open the air filter housing to check that too, and was a bit stunned to find...
That the filter was a bit holey!!!
amd the element itself has just fallen to bits
Here's what's left of the filter material in the bottom of the air cleaner housing
Rubbish had covered the throttle plate too. By the looks of the black foam missing in the first pic, my engine ate a lot of filter!!! 8O
Air flow meter was chocked up too
Granted the filter was a few years old now, but I thought these things were supposed to be "the last filter you ever buy".
aka
aka
Post Posted: Sun Jan 04, 2009 4:19 am
I thought those filters were the bees knees, might have to refie that opinion!
Hope there is no damage to your donk!
Experience is something you dont get until just af
what did you last clean and oil it with, Napalm?
Post Posted: Sun Jan 04, 2009 4:22 am
I have only used the proper cleaner and oil for it. I'm thinking the previous owner may have gone the dodge though.
In any case, it's rooted now.
lesspostingmorewheeling
Post Posted: Sun Jan 04, 2009 4:24 am
i'm sure you could fix the foam :wink:
Post Posted: Sun Jan 04, 2009 6:35 am
i have had dramas with a few different types of filter.
i stick with the paper ones now
Post Posted: Sun Jan 04, 2009 1:50 pm
Was a finer filter in mine when I bought the car too, and it looked just like that one. I'm not a real big fan of air filters that need to be oiled, so I replaced it with a stocko paper one.
Post Posted: Sun Jan 04, 2009 1:58 pm
That's probably the cause of your idle issue too Damo. What are you going to clean the throttle body and intake with? I used an awesome product from Three Bond to clean my carby the other day, it's sooo shiney inside now!! It's called Engine Conditioner.
Post Posted: Sun Jan 04, 2009 2:05 pm
fark..... id hate to know how much of that got into your engine....
luckily its only foam and shouldnt cause too much damage.
how long was it in between servicing it?
Web wheeler extroadinaire
Post Posted: Sun Jan 04, 2009 5:26 pm
i run a finer filter in my 1.3 & check it every 5000klm & service it ie: wash & oil filter once a year . no problems for about 5 years. basically you need to check regularly damo. 8)
Post Posted: Sun Jan 04, 2009 10:24 pm
You're right. It won't do any damage to the engine, but I'm not so sure about the air flow meter. I would be using carby cleaner to clean out the throttle body, and maybe a light blow out with compressed air through the air flow meter to get all the crap out. If it does have a problem with idle as already stated, I'd be pointing the finger at the air flow meter.
Post Posted: Sun Jan 04, 2009 11:12 pm
Nah, more likely the IAC full off foam
Post Posted: Sun Jan 04, 2009 11:39 pm
I'd use AFM Cleaner on the AFM. WHilst a light blow may get the large crap out, it probably won't get rid of any oily residue which can make the meter play up and not work properly.
Then throw it all away and get a paper filter.
Post Posted: Sun Jan 04, 2009 11:58 pm
X2....paper all the way.
Post Posted: Mon Jan 05, 2009 1:17 am
Nah, AFm is rooted and has been disconnected for months 8)
Post Posted: Mon Jan 05, 2009 7:30 pm
Called around and got prices for paper filters. Was a bit 8O at some of the prices!!! Most had to order in as well.
Thanks to Lance from Qld 4WD, who had one on the shelf for $22.
Post Posted: Mon Jan 05, 2009 9:31 pm
i wait until repco have there crap oil , oil filter and air filter sale. $30 dollars or so and then give the oil away and use the filters.
Post Posted: Tue Jan 06, 2009 12:31 am
last time i got my air filter it was $14.55 from repco but that was slightly discounted
Users browsing this forum: Google [Bot] and 261 guests
