i have been trying to put my air lockers together this weekend with 4.8 diff gears from a vitara. I am having a massive amount of trouble with the diff flanges.
So far i have pulled apart 6 diffs with WT style flanges on them and only 2 of the 5 will slide onto the pinion. The others will press on and off but when you look at the wear pattern on the splines it seems they are too tall to properly fit in the flange.
Does any one know if the early WT ones were different to the coily and vitara flanges?? any one had similar issues?
Users browsing this forum: No registered users and 203 guests
