It is currently Sat Oct 24, 2026 3:59 am
Post Posted: Sun Nov 20, 2011 10:20 pm
Ha Fooled you all already. you all thought this was another Jimny thread!
So anywho now that i've had my fun. My LWB Vit, has developed a wobble in the steering. So far this is what i've tried
-New Inner & Outer Tierods
-New Draglink
-Wheel Balance / Alignment
-New Wheel Bearings.
-Flushed all the old P/s fluid out for new stuff
Currently Running 31 x 11.5 R15 (rims are -23) Mickey Thompson Baja Claws on a 3" Calmini Suspension setup with a 2" Body Lift.
I was thinking about pulling the Steering box out and putting a Seal kit through it
http://www.suzistore.com.au/shopexd.asp?id=1615
as its the only thing i can think of thats causing this. and if that doesn't fix it maybe a RTC Dampner ( i've been advised that this should be a last resort as it tends to mask the problem rather than fix it )
Any other ideas?
Stocker
Post Posted: Sun Nov 20, 2011 11:12 pm
what struts are you running?
have you checked to see if there is much run out on the rims?
Vehicle: 1995 swb vitara
Post Posted: Mon Nov 21, 2011 1:47 am
Have you got access to stock rims/tyres to trial
The shake is it through the car or the steering wheel
Through the car could be a uni ??
Post Posted: Mon Nov 21, 2011 3:48 am
No its just through the wheel, and no i don't have access to stock rims / tyres.
Im not quite sure what you mean by this, could you explain further please :blink:
Stocker
Post Posted: Mon Nov 21, 2011 3:54 am
what struts are you running? eg OME, Calmini, Ironman etc... as in one could be seized.
run out is the wobble in the rim left to right/up & down when spinning it. Axial=side to side and Radial=up and down
Post Posted: Mon Nov 21, 2011 4:07 am
Struts are : Dobinson 2" Lifted in the front and Calmini ones in the rear. they aren't seized i just checked them.
and from what i can tell everything looks normal in the "run out" department
Stocker
Post Posted: Mon Nov 21, 2011 4:11 am
What width are the rims? 11.5 is a pretty wide tyre for a hairdressers car 8O :lol:
Post Posted: Mon Nov 21, 2011 4:14 am
they are on an 8" Rim.
Just so i've said it, the problems only occured in the last few weeks, have been running this combo of parts fine for the last 3months
Stocker
Post Posted: Mon Nov 21, 2011 4:16 am
Have you rotated wheels front to rear? What's the wear like on them? Even?
you'll need to measure run out with a dial indicator, you're eye probably wont pick it up unless it's mega bent or you have super human bionic vision.
Post Posted: Mon Nov 21, 2011 4:45 am
i see... i'll go with the super human bionic vision then :)... i'll have to borrow one from work 2morro...
Really considering a SAS at the moment...
Stocker
Post Posted: Mon Nov 21, 2011 4:46 am
new or 2nd hand rims?
Post Posted: Mon Nov 21, 2011 4:47 am
2nd hand rims. ones i got off Brett
Stocker
Post Posted: Mon Nov 21, 2011 4:55 am
could quite well be a slight buckle in the rim or an egged tyre, i know my speedy desert rat rims had a fair bit of runout brand new before even having tyres fitted.
Post Posted: Mon Nov 21, 2011 4:56 am
Also might be a good time to mention that she is still lifting one of the front wheels when you come round a corner and give it a boot full... thinking the rear coils might be a smidgen soft...
I was thinking of maybe putting another set of coils in the rear with a 2" Lift and getting a 1" Spacer... has anyone else had troubles with the coils being too soft?
Stocker
Post Posted: Mon Nov 21, 2011 5:10 am
Mine are way too soft too, especially when packed for camping bottoms out over hi-way bumps pretty bad.
Post Posted: Mon Nov 21, 2011 6:26 am
Have your front tyres scolloped?? As in uneven were it's happend in my mates cruser do a rotation and see if that helps
Post Posted: Mon Nov 21, 2011 7:01 am
At what speed does it shake at
Slow speed around 25-50 kmh could be rim/tyre runout
Above that could be balance maybe lost a wheel weight
The exception being a scalloped tyre
As above try the rotation
Post Posted: Mon Nov 21, 2011 9:08 am
Will definitely try the wheel rotation, all the tyres are pretty well rooted, just saving up now for the new set now... Was also thinking about getting some Smaller rims ( 15 x 7 ) still with a big neg offset though...
cant decide whether to go 235 / 75's or just man up with the 31x10.5's.
i think the 11.5's are a bit wide as they scrub on the chassis rail even with the massive offset.
Stocker
Users browsing this forum: No registered users and 81 guests
