It is currently Sun Nov 01, 2026 3:28 pm
Post Posted: Tue Nov 22, 2011 6:08 am
Eu guys and girls what's the easiest way to get the fly wheel bolts off?? Cheers also might add I can't get my hands on a rattle gun till tomorrow
Post Posted: Tue Nov 22, 2011 6:17 am
use some muscles you limp dick :roll:
they are not that tight
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Tue Nov 22, 2011 6:19 am
Jam a big screwdriver in the teeth to something else or even in the front pullys. Do it's wedged then use a breaker bar and try do a short hard burst instead of a constant pull. U wanna crack em loose so to speak!
Post Posted: Tue Nov 22, 2011 6:20 am
Is in or out of car?
You need a way to stop motor turning.
Spanner on crank pulley is one way.
And a decent socket with a very long bar.
Or a pole to slip over a short bar.
Watch ya knuckles,
fly wheel teeth bite.
Post Posted: Tue Nov 22, 2011 6:22 am
PS, on odd occassions, crank pulley comes loose instead
Vehicle: LWB Sierra & XL7
Post Posted: Tue Nov 22, 2011 6:38 am
Easiest way, air impact wrench.
Otherwise use screw driver to jam it in the teeth and use a breaker bar.
'92 Vitara & Camper trailer
Vehicle: LJ20 LJ50
Post Posted: Tue Nov 22, 2011 6:47 am
tyre lever jammed though starter motor hole and then undo.
rough way is to undo spark plug get on firing stroke (so valves are shut) make sure piston is as low as it will go and feed rope into the cylinder until you cant squeeze anymore in then use a breaker bar and kick it.
or you could use a square edged big screw driver or bit of flat steel and follow noob cad pic. Just loosen bolts using this method IE 1 and 2 then turn a bit anddo the next two. Best if you can just wedge it against chassis rail ground and give a kick
Camels have nice toes
Post Posted: Tue Nov 22, 2011 6:55 am
Thanks for that buddy all good now to do The one that's a bare block hahaha
Post Posted: Tue Nov 22, 2011 6:58 am
The next one I can't damage as I need the flywheel the first one is in good nick don't need it awesome as thanks for the help guys much appreciated
Also my knuckels are in goOd nick no damage
Post Posted: Tue Nov 22, 2011 7:02 am
air gun is the easy way 8)
josh AKA Bazook
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Tue Nov 22, 2011 9:07 am
without a impact wrench get a decent socket and breaker bar with a hammer and block of wood
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
Users browsing this forum: Google [Bot] and 239 guests
