It is currently Sun Aug 02, 2026 5:10 pm
Post Posted: Fri Nov 25, 2011 8:35 am
soo i drive her around for abit.. then when i pull up to the lights n have to wait abit the revs drop a lil the car shakes abit then when i take off shes all "put put put put" like. then the power starts to cut in n out, ive seen tiniest bit of white smoke come out and then i give her the berries then shes coughs her way to normal.. then everything is fine.. but she done this abit in the last week? any thoughts?
oh n is this legal?
(where the spotties r mounted)
If in doubt power out!
Post Posted: Fri Nov 25, 2011 8:52 am
Check the coolant level in the radiator and the oil level in the engine. Also take a quick look at the underside of the oil filler cap.
Spots should be ok there
Post Posted: Fri Nov 25, 2011 8:56 am
can u take a look over the weekend mate? if ur free?
Post Posted: Fri Nov 25, 2011 9:01 am
At a random stab in the dark it could be bad fuel/ fuel filter or pump or maybe even air filter? i always check the basics
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Fri Nov 25, 2011 9:02 am
could be water in the fuel?
Post Posted: Fri Nov 25, 2011 9:06 am
yeah i had a case of bad fuel, then i changed the fuel filter n a shit load of carby cleaner, she's alot better then she was.. ive got a new air filter but i have to find some pipe to hook up my snorkle as i have a pod filter there at the moment
Post Posted: Fri Nov 25, 2011 9:13 am
yep thats probably done it.
Post Posted: Fri Nov 25, 2011 9:14 am
how do i fix her?
Post Posted: Fri Nov 25, 2011 10:55 am
8O bit off topic but is your dash and steering wheel all green
josh AKA Bazook
Post Posted: Fri Nov 25, 2011 6:51 pm
plugs do that. change em.
Post Posted: Fri Nov 25, 2011 10:37 pm
yeah its all bright green.. safety feature!
change plugs n leads?
Post Posted: Fri Nov 25, 2011 10:51 pm
Pull the plugs and note the condition. Either clean them or replace them, probably worth replacing anyway.
Spotlights are fine just need to be on a relay to only come on at high beam
Post Posted: Fri Nov 25, 2011 11:50 pm
yeah its hooked up properly, just wasnt sure if they would cause me police/department of transport trouble.
is it worth getting top notch plugs?
Users browsing this forum: Google [Bot] and 311 guests
