It is currently Sun Aug 02, 2026 11:56 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Post Posted: Mon Nov 28, 2011 6:22 pm
Can you not make another bracket to suit the diff end and run some new Monroe shocks?
Post Posted: Mon Nov 28, 2011 7:33 pm
Nah- I was on my iMac at home- I'm on my iPhone now and can see it fine. I reckon there is room for the reservoir based on the photo you posted. Worst case might require some clearancing of the mount, but not much.
Post Posted: Mon Nov 28, 2011 11:39 pm
Ok, so hoW do I know which one I would want. 6"...14" IS that travel or Extended Legth? EL is the most important measurement for this type of setup.
I really don't think a fixed reservoir would fit. Would have to cut out some of the shock tower and I think that would be a no no.
I asume that the stem adapter can be fitted at either end?
Post Posted: Mon Nov 28, 2011 11:48 pm
monkey wrote:
:? Your coil/shocks tower's aren't bent at all are they?
Not that I know
monkey wrote:
What arm's are those? 3" jimnybit's arms, with 80mm TD coils?
Custom made by someone who I cannot name. I was told they were CroMoly but they are not, which is why one bent and the other broke 2 weeks ago. So now they are straightened and repaired.
Post Posted: Tue Nov 29, 2011 2:15 am
monkey wrote:
Pic works for me....
Are you using a i-fail? :lol:
Do you mean iPhail
Post Posted: Tue Nov 29, 2011 6:48 am
If you push it back to far, you get the body of the shock (body at bottom) closer to the tower surround in the upper half of the stroke I would think.
Also. I note that there is a little space above the chassis on the inswide of the shock tower. I wonders if the reservoir of the 5150's would sit neatly in that space. Its only about 60~70mm though. Would depend on the distance between the mounting point and the bottom of the reservoir.
Post Posted: Tue Nov 29, 2011 7:06 am
Do you mean iPhail
haha, i wouldn't be bagging the only person offering alternative shock tech on their choice of operating system. :roll:
Post Posted: Wed Nov 30, 2011 8:29 am
So with the sort of driving we do, are the 5160's or even 5150's of any benefit?
Users browsing this forum: Google [Bot] and 314 guests
