It is currently Sun Sep 20, 2026 2:24 am
Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3
Post Posted: Mon Jun 13, 2011 9:06 am
I'm pretty sure there is 4 but I'll check for you tomorrow.
It may end up with 3 as I'd still like it about an inch lower
Post Posted: Mon Jul 11, 2011 12:33 pm
has any one got any examples of how they did it to a wide track, or do you need to move the hangers in?
Post Posted: Mon Jul 11, 2011 12:35 pm
Have a look in my build thread to get an idea. I'm RUF on stock WT spacings
Lil Foot!
Post Posted: Fri Oct 07, 2011 4:22 am
Nice write up there. By any chance did you want to come up to.qld and do this to mine? Beer supplied...
Post Posted: Sun Nov 27, 2011 11:47 pm
is there any implications with doing a RUF on a SPOA vehicle ? mines SPOA Nt chassis with Wt axles on 33's i like the idea of moving the front axle foward for firewall clearance
Post Posted: Mon Nov 28, 2011 9:05 am
Im no expert but from what I could think of you would need to consider.
The changes to SPOA geometry???
RUF from what I understand is not great with handling at high speed?
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Sat Dec 03, 2011 10:31 am
i just want to get all the gear i need to do a RUF but i am unsure of what springs i should use. my current set up is a 2 inch king spring lift so the question is do i use a standard rear (stock) spring or do i use a 2 inch lifted rear king spring up front????
thanks greg
Post Posted: Sat Dec 03, 2011 12:47 pm
i run hilux fronts all round SPOA and passed the lane change test here in WA... so long as the shocks are valved right and the caster is corrected when welding on the perches it should handle fine (infact you could dial in a touch more and have it handling better, which is how mines done).
Post Posted: Sat Dec 03, 2011 7:00 pm
hey guys im about to get my ruf done by 2stroker, i have a couple of questions. which rear springs do i buy i think they are 2 inch lifted efs??. also how much luck have you lads had in the past with shock hoops?
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Tue Dec 06, 2011 11:43 am
nope, it will loosen up the front end considerable (body roll) and make it ride a whole heap better, mine is spoa+ruf. Alien is on the money.
Users browsing this forum: No registered users and 42 guests
