| Author |
Message |
Glider
Joined: Sat Oct 29, 2011 3:44 am Posts: 12 Location: Edith via Oberon NSW
Vehicle: 94 Sierra QX JX
 Posted: Sat Dec 03, 2011 8:36 pm |
I am installing a new radiator in my 94 SJ70 and wondering if I need to bleed the air out of the system when the new coolant goes in. If so, are there any special techniques to be used?
Mick
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sat Dec 03, 2011 8:51 pm |
it should bleed it's self..... i think, i never had to bleed mine....
royce
 Posted: Sat Dec 03, 2011 8:52 pm |
just fill it up with coolant (hopefully youve flushed all the old stuff out already) and turn the heater on and run it, I find it helps to hold the revs up at about 1500rpm so the water pump pushes coolant up to thermostat better
once the thermostat opens youll need to top it up again, watch the temp below the thermostat doesnt get too high you cant touch the manifold, letting it idle will hold the thermostat shut so the coolant doesnt flow
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
I usually fill it up, then run the motor and squeeze the hoses till no more bubbles come up.
_________________ mlm
shakes
Joined: Sat Apr 10, 2010 11:30 pm Posts: 4895 Location: Northcote
 Posted: Sat Dec 03, 2011 9:30 pm |
SierraDan wrote: I usually fill it up, then run the motor and squeeze the hoses till no more bubbles come up.
thats what I do too - than as royce said, hold the rev's up until you see that water in the radiator drop (a good sign the thermostat has opened) top up replace radiator cap and drive for a few minutes, let cool and check levels.
Glider
 Posted: Sun Dec 04, 2011 1:07 am |
Thanks guys! All good stuff. The new radiator goes in tomorrow if they deliver the right one this time.
Mick
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Sun Dec 04, 2011 1:45 am |
if you're putting in a new rad make sure you put new hoses in too... they dont cost much and you'll have better piece of mind.
ZookFan
Joined: Mon Feb 14, 2011 6:19 am Posts: 3978 Location: Brisbane,samford,QLD
 Posted: Sun Dec 04, 2011 8:41 am |
X2
