It is currently Fri Nov 13, 2026 10:04 am
Post Posted: Sun Dec 04, 2011 11:30 pm
I know when this conversion is done the u-bolts start riding up further on the centre section of the housing. Are different size u-bolts required? I was hoping to use my stock WT u-bolts but don't want to get into it and find out I need new bolts!!!
Post Posted: Sun Dec 04, 2011 11:45 pm
yep, there are the same size but longer.
Post Posted: Mon Dec 05, 2011 12:30 am
Thanks mate, that was exactly what I wanted to hear!!!
Post Posted: Mon Dec 05, 2011 1:02 am
I found that the wt ubolts were pushing it.
When I did mine I could just get a full length nut on the ubolt that sits up on the pumpkin
Post Posted: Mon Dec 05, 2011 1:09 am
I said before stock WT u-bolts, but that was misleading. I'm sure mine are an aftermarket so are a little longer than stock. Lucky I hadn't got around to trimming them haha!
Post Posted: Mon Dec 05, 2011 1:30 am
Oh my mistake. I forgot to say mine were aftermarket ones aswell
Post Posted: Mon Dec 05, 2011 1:32 am
When I did mine I reused all u bolts except the ones on the front diff driver side.
I found out the hard way putting it together and had to source 2 new one they come close but just. It close enough
 Profile YIM
Post Posted: Mon Dec 05, 2011 1:33 am
They fit over the housing but were just a bit short?
Post Posted: Mon Dec 05, 2011 2:32 am
Yep
 Profile YIM
Post Posted: Mon Dec 05, 2011 2:37 am
Come to think of it on the r/h/f you may need a slightly larger u bolt I used the std but longer ones and had to use a G clamp to get them through the plates
 Profile YIM
Post Posted: Mon Dec 05, 2011 5:13 am
NT RHF inside Ubolt is both larger diameter U and longer than all the other Ubolts.
To do it properly you really need the Ubolt guide thing from the top of the NT axle tube as well as the RHF lower spring plate.
Post Posted: Mon Dec 05, 2011 5:18 am
The guide on the axle tube is obviously welded to the housing right?
Are they of similar design to the WT ones but to suit a different position?
Post Posted: Mon Dec 05, 2011 5:21 am
that part of the housing is the same so if you grind of the n/t one and weld it to the w/t diff in the same place as it was on the n/t diff.
dose that make sense??
 Profile YIM
Post Posted: Mon Dec 05, 2011 5:23 am
Yep that makes perfect sense! thanks fellas
Post Posted: Mon Dec 05, 2011 6:46 am
X2 jas is spot on
Post Posted: Mon Dec 05, 2011 6:55 am
It does. But if its what im thinking.. it'd be easy enough to make one.
Post Posted: Mon Dec 05, 2011 9:18 am
Why, when there is only 4 lil weld's holding it on....& look original
Post Posted: Mon Dec 05, 2011 9:24 am
I dont wanna wait till i find a NT housing though.
Post Posted: Mon Dec 05, 2011 5:58 pm
i have one i think....
Post Posted: Tue Dec 06, 2011 2:08 am
Okay, ill wait till you get back before i start on it then.
Users browsing this forum: No registered users and 37 guests
