It is currently Thu Oct 29, 2026 3:26 pm
Post Posted: Mon Dec 05, 2011 6:08 am
Really not shore on my slow tin top it's lucky to get to 80ks it will hit 100 down a hill with wind.. Is this right??? O its stock 1.3 5 speed??
Post Posted: Mon Dec 05, 2011 6:20 am
what size tires are you running?
my 1.3 wt with 31s and 6.5 gears sits on abot 80km/h on the speedo on the highway. can get it up to 100 on the speedo on a downwards slope bit. haha
Vehicle: 93 Sierra
Post Posted: Mon Dec 05, 2011 6:21 am
It ain't running right. My tintop stocker would do 110kph on the flat without dramas, though headwind or uphill could pull it back to 90-100kph. Most 1.3's should be able to cruise at 100kph without drama.
Vehicle: 1985 Holden Drover
Post Posted: Mon Dec 05, 2011 6:54 am
Mine says 80kms on the speedo when im actually doing around 100ish (on the GPS that is)
Doesnt sound too bad? Unless mines fucked too :lol:
EDIT: do the 6.5 gears put the speedo back in sync? Just re read it.
1989 WT Sierra.
Vehicle: Sj70 tintop
Post Posted: Mon Dec 05, 2011 7:14 am
dunno whats wrong with all your fellas cars and speedos,
but mine says 100 and the gps says 106km/h
thats stock 1.3 5 speed with 4.1 gears 1 litre transfer and 31'' muddies.
also it has no trouble sitting on 100, untill get to a hill.
Sj70 tintop
Vehicle: 1995 Sierra 1.3
Post Posted: Mon Dec 05, 2011 7:44 am
This link may give you some indication of what type of performance you should expect from your Zook. Everyone's performance differs as everyone has different set ups (engines, gearing, tyres etc)
http://www.auszookers.com/index.php?nam ... h&start=30
Your zook sounds like its motors a bit tired and may be ready for a rebuild.
Post Posted: Mon Dec 05, 2011 7:58 am
i have 235/75's and fully loaded i get 110km, but i usually sit on 105 in fourth gear. fith is useless ((i still have stock gears and stock motor). strangely enough unloaded i still only get 120km if there is no wind.
i have played with different timing and different fuels.
oil lights are like oven alarms, let u know its co
Vehicle: '94 suzuki maruti
Post Posted: Mon Dec 05, 2011 11:14 am
i run stock motor & gears, on 31s i can hold 100k's (gps speed) on flat ground in 4th gear... it struggles to hold 80k's in fifth :roll:
Vehicle: ute
Post Posted: Mon Dec 05, 2011 12:09 pm
Mine with 1.6l, 6.5's and 34's does 105kph speedo says 75 wont hold 5th over 80 :blink:
Post Posted: Mon Dec 05, 2011 12:20 pm
you have a heap more high range reduction then a stock wt sierra. 12% just in the transfer.
Post Posted: Mon Dec 05, 2011 12:24 pm
mine does 110kph 1.6 efi (210xxxkm) with stock 5.12 diff gears in 5th on 31's really easy, everyone that says they cant use 5th in there vitara is lying!....yes i know this thread is for sierra's
Post Posted: Mon Dec 05, 2011 5:52 pm
I will check my tyres.and yea the motor is old stock by the look of it..
Yea I didn't see the point of 5 th. Lol I will try the gps
Thanks
Post Posted: Mon Dec 05, 2011 6:56 pm
ths is true,
but before this zook i bought a n/t lwb of 2stroker.
31's 1.3 carb 5 speed 1.3 stock transfer and 3.7 diffs.
still sat in 5th doing 100 (gps) all the way from brissy to darwin fully loaded.
Sj70 tintop
Post Posted: Wed Dec 07, 2011 1:23 am
Yea I'm in the same boat, stock 1.3, 235's and coming up to 270 on the clock.
If there is no wind on the flat I can manage about 90, 80 with a headwind. On my last trip north some hills took me back to 3rd.
I used to get 400klms per tank and now its 300-330, how much of that would be due to the wrong speedo reading?
Post Posted: Wed Dec 07, 2011 1:32 am
The best thing I ever did to mine was rebuild the carby and stick bigger jets in, especially the secondary throat. I had 31's with just a 1L transfer and it would accelerate easily up from 100kph
Post Posted: Wed Dec 07, 2011 1:39 am
bigger tires will give an incorrect speedo reading, also will give a wrong odometer reading, best bet is to use a gps and work out the error so you can calculate the difference
i.e 400km on my odometer, i have actually done 440km
Sj70 tintop
Post Posted: Wed Dec 07, 2011 8:55 am
Lol now I have to fix my sig lighter !!! Good dam
Users browsing this forum: No registered users and 301 guests
