It is currently Tue Oct 13, 2026 11:59 pm
Post Posted: Wed Jan 14, 2009 12:47 pm
We have done the above conversion and have found that the spark fires for about 2 seconds and then there is no spark at all then if I continue to crank . It sounds like the injectors are doing the same
Gathering circuit diagrams I have 3 now and none fit the Australian G16B ECU which has 3 plugs going in to it.
Does anybody know where I can get a circuit diagram for an Australian Vitara 91 to 98 . It was manufactured in Japan
Post Posted: Wed Jan 14, 2009 2:58 pm
Mine is differnt to that, it has 2 plugs going into the ECU. Baleno's have 3 plugs, but their ingition system is different.
Are you sure you have a Vit motor?
Post Posted: Wed Jan 14, 2009 5:42 pm
my engine is out of a 93 vit G16B MPFI and it only has two plugs.
Post Posted: Wed Jan 14, 2009 11:18 pm
mine has 3 plugs, its out of a baleno, im still looking for a wiring diagram so if you find one, please let me know
ps
good luck!!!
85 NT, SPOA, 2" BL, sliders, f&r lockers, bull bar
Post Posted: Thu Jan 15, 2009 12:36 am
This may help.. :wink:
http://www.balenoklub.cz/pages/clanky/e ... talace.pdf
Post Posted: Thu Jan 15, 2009 1:18 am
91 to 98?...there are about 6 different types of 'b' motor in those years.
Post Posted: Thu Jan 15, 2009 2:25 am
Thanks want33s
Thats for 1996 System Wiring Diagrams
Suzuki - Esteem
and I cant recognise the wiring as the same as ours. If I read it right that model has four plugs in the ECM , is that right ?
Im getting the feeling its a prior year to this so perhaps 91 to 95 ?
Baleno may be a possibility ,I will try to attach a picture. Can anybody pick anything from these?
Post Posted: Thu Jan 15, 2009 2:28 am
I wasn't sure if it was correct or not. Might be wrong years.
Esteem.. Baleno= same car..different markets.
PS: You might want to move that pod filter from above the manifold. They burn easily, besides you don't want the engine sucking hot air.
I'll dig a bit deeper...see if I can find more diagrams. 8O
Post Posted: Thu Jan 15, 2009 2:30 am
looks like a type2....how many wires go into the dizzy?....and where is the airflow sensor?
Post Posted: Thu Jan 15, 2009 3:11 am
Distributor supplied has 2 wires ,red and white from memory. The wires on the loom though are different colours ,blue/ black ands something else ,not sure . Two pickups in the dizzy one after the other. Air flow sensor had no place to go so we put it in the short rubber piece before the throttle.
Fine want33s , I cant go anywhere atm.
Post Posted: Sun Jan 18, 2009 1:13 pm
Bump
We have hit a lull here
Has anybogy got a site I can search on to find the electronic circuit diagrams please?
Post Posted: Sun Jan 18, 2009 1:27 pm
There are some manuals in the download section, and you'll also find some stuff on www.suzukiinfo.com.
Users browsing this forum: Google [Bot] and 270 guests
